Towing an XJ6
vping
Bronze
I am towing an XJ6 about 60 miles with a tow dolly and wondering if there will be any issues or concerns. I've used this dolly to tow MG's with ease. It's a Master Tow dolly and I am using my Expedition. The car's wheels are free but I am unsure if I should disconnect anything before I go or can I just hitch it up & go.
If you could PM me I'd appreciate it.
Thanks
Vince
Paul Johnson
If it's an automatic, you may have problems. I cannot remember, but if the oil pump on the Jag is splined to the input shaft, then you should not tow.
When the rear wheels are turning, so is the drive (prop) shaft, and so then are the box internals. They will not survive 60 miles.
On the MGB the same situation applies, as the wheels are turning the gear (upper) shaft. The countershaft, in the bottom of the case is not turning, and it is that turning motion that splashes oil to the gear shaft. However a manual box will survive about 500 miles without needing to be driven a bit to re-splash the gears. An automatic will not.
An alternative choice would be to place the back wheels on the dolly and lock or tie the steering wheel straight.
tony barnhill
Great Pumpkin - R.I.P
somewhere on this or another thread that I ca't find, I answered "if I were to move my XJ6 anyway but under its own power, it'd be on a roll-back"...can't find that post but the answer is above...I'd be afraid to flat tow an automatic transmissioned Jaguar
vping Towing an XJ6 Jaguar 2
B General MG Does odometer record when flat towing. MG 5
jlaird MGB towing MG 13
TR3MT TR2/3/3A towing a TR3A with a rigid towbar Triumph 6
longbridgehealey Towing BN4 on trailer Austin Healey 10
bugedd Towing a Sprite Spridgets 31
doc50 TR2/3/3A rear suspension / towing... Triumph 9
Boggsy64 MGB Towing MGB MG 12
P MGB Towing an MGB? MG 8
Cottontop Flat towing a TR 4 Triumph 1
T Rear Towing Eyes Austin Healey 4
Rut Towing a bugeye Spridgets 25
Cottontop Towing a Healey Austin Healey 32
V flat towing? Triumph 10
theleisure Towing a Spridget Spridgets 9
C Hitches / towing with a midget Spridgets 10
lbc_newbie 78 Midget towing Spridgets 5
M Towing suggestions Spridgets 11
C Wedge towing a TR8 Triumph 7
kennypinkerton MGB MGB towing capacity? MG 2
Atrus Let's talk towing a spridget! Spridgets 10
Gray_Cat Towing a 56 BN 2 Austin Healey 5
M towing my mini British Motor Corp 11
Jack_Long towing a Midget Spridgets 10
G Tommy's Towing Service Triumph 3
W Towing with a Jeep Grand Cherokee. Other Cars 10
YankeeTR Spitfire OK...Who was towing their Spit in Indiana on Sat ? Triumph 0
6 TR6 towing a TR6 Triumph 5
RTR52nd Towing the B?? MG 4
B Towing an LBC on a dolly? Spridgets 3
MgKid1974 MG Towing Package??? MG 8
J Spitfire Towing a Spitfire Triumph 34
G Towing with a cover....not too smart? Triumph 9
G Towing question.... Triumph 6
B TRIUMPH TOWING not needed Triumph 3
B CAR TOWING MG 0
B CAR TOWING Triumph 0
AUSMHLY Towing Eye Austin Healey 6
V Towing Tips Triumph 4
H Towing 62BT7 with Drive Shaft Connected Austin Healey 4
vping Towing an MG MG 21
sparkydave Towing question Other Cars 0
AngliaGT Towing Restoration & Tools 2
KVH TR4/4A Towing a TR4 Triumph 7
AngliaGT Trucks for Towing Other Cars 21
T Help towing a Triumph Triumph 6
Y Europa Towing Points Lotus 2
Michael Oritt Towing and transmission damage Austin Healey 3
TNMGB Towing MG 12
G T-Series Towing MG TD MG 19
