Kim,
The last dolly that I used had a pivot independent from the locked front wheels. Basically, there were two parallel plates, the bottom connected to the dolly wheels, in the center bolted together so they could rotate and the top had the healey wheels tied down to it. Therefore, if you locked the steeringwheel straight, you could use it to two backwards.
Ben
