TR6 Front brakes won't release
I had locked up brakes. It turned out that the spring inside the master cylinder had compressed and not returned to its full length, causing the tip valve to remain closed. So every time I stepped on the brake it pumped more fluid into the master and lines, totally locked down the wheels. Temporary fix was to open the tip valve by inserting a small tool(coat hanger wire) into the hole in the bottom of the reservoir to release the pressure. You'll see a little squirt of brake fluid come up. It only takes a slight pressure. I stretched the cylinder spring out and have been driving it for the last 30 years. (Ive had the thing since 1980). Did your master replacement come with the plunger and spring already loaded? Maybe the spring isn't strong enough. Maybe the rubber seals may have swollen with the wrong brake fluid? I use the silicone fluid for brake and clutch.
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
ncbugeye Front wheels won't spin, dsic brakes binding? Spridgets 13
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
K TR2/3/3A Sticking front brakes? Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
C 100-6 front drum brakes? Austin Healey 36
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
P Front drum brakes - fluid lines Austin Healey 12
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
trrdster2000 Post-War Other Front brakes on the Roadster Triumph 5
R BJ8 Front Brakes drag some Austin Healey 9
T TR2/3/3A TR3A front brakes Triumph 2
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
M Stuck front brakes? Spridgets 8
M Front brakes are sticking Spridgets 33
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Stewart Dragging front brakes MG 7
B front disc brakes- 66 sprite Spridgets 8
RickB Front brakes seizing - what's with that? Spridgets 23
M Slight bind in front brakes Spridgets 7
R Front Brakes... Spridgets 7
sparkydave Dragging front brakes Spridgets 4
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
T Time to redo all my brakes and front suspension... Triumph 14
S TR2/3/3A tr3 front brakes hoses Triumph 9
drooartz Installing front suspension/brakes - review Spridgets 1
zschicago my first Healey and questions about front brakes Austin Healey 10
v8mgbal front brakes Spridgets 9
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
Brosky Front Suspension & Brakes -Done Triumph 5
N TR6 Clip wires on front brakes for TR6 Triumph 9
eejay56 BMW 320i front brakes locked up Other Cars 8
1 front brakes Spridgets 3
19_again leak front brakes MG 6
M front brakes Spridgets 12
M front brakes Austin Healey 3
jmwuva05 Front drum brakes. Spridgets 2
zimmy front disk brakes Spridgets 9
T TR4/4A Early TR4 - Front Brakes Triumph 3
zimmy front brakes and calipers Spridgets 3
R TR6 TR6 front brakes Jack Drew Triumph 13
