Front wheels won't spin, dsic brakes binding?
ncbugeye
ncbugeye began to squeak a couple of weeks ago, it came from the right front. It started before I got my new wheels (the new Superlites from Hap Waldrop), but while changing them, I noticed that the right front wheel was really hard to turn by hand. It's still drivable, but I think I need to take a look at it. No play or wobble to speak of, just really hard to spin.
What might be wrong here? Brakes binding? Bearing shot? What else? Note that ncbugeye has front disc assemblies from (I think) the same 1974 Midget which donated its 1275cc engine.
I seek advice from the wise and worthy sages of the great Librica brotherhood.
Billm
First thing that I would do is to gently pry back the pads to be sure that they are away from the disk and then try to turn it. That will at least narrow down the search.
Bill
John Moore
How old are the brake hoses? They break down, inside out and can cause the calipers to fill up with junk and bind.
ncbugeye
ncbugeye
I assume they are of 1974 vintage, the donor car was plundered in the early 1990s as far as I know, there is no sign of them being replaced more recently.
tony barnhill
Great Pumpkin - R.I.P
What year car is it? & does it have a dual or single brake system?
ncbugeye
ncbugeye
Tony, my sig says it all...
(I think the MC is original Bugeye)
tony barnhill
So, its a single line system...rules out my prognosis.
Platinum
billm said it: try getting the pistons back into the caliper some to see if the hub spins freely. I'm guessin' you're gonna have a hard time doing that. For sure do as John suggests: replace the flex lines. They deteriorate from the inside and "valve" pressure. Do the back one too, you'll have the system open and need to bleed it anyhow. Now's the time.
"Might as well". /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
kcbugeye1275
I vote with John on the brake lines. They collapse with age. So the fluid goes out and doesn't come back. You might think about the braided steel lines. They will make you brakes feel more solid. Besides, they look really nice.
Platinum
...duelling posts... or is that dualing... /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
racingenglishcars
Though it is very likely that the flex line is deteriorated, it is also likely that the caliper is rusty. If the pads are hard to pry back, loosten the bleeding nipple and try again. If it's still hard to pry the pads back, the caliper is rusty. At this diagnosis, remove both calipers, disassemble, clean, remove rust inside the cylinder, install new rubbers, if pistons are rusty then replace them, reassemble, and then install new flex lines and bleed the system.
R
RonMacPherson
I dunno what you've done so far. I got into this one late, but want to add a little advice.
If you haven't tried compressing the pistons, open the bleed screw. If a pressure buildup is there, fluid spurts out, rather than dribbles out, you've got pressure not releasing in the system. Where could that be, most logical is the hoses, 2nd is a pdwa valve or proportioning valve, 3rd is interior of the master cylinder, but this is rare on a disc brake car.
Hopes that helps in isolation.
If you don't get a pressure release look at the pistons to see if they are rusting or seals hardened and not letting the pistons return.
ncbugeye
ncbugeye
Wow... Thanks for all the ideas, BCF comes though again, and it looks like I have a busy weekend ahead of me.
I will definitely replace the hoses, and seriously consider the stainless steel sheathed ones, they are only a bit more expensive, so I might go for those. And will look at the condition of all the parts.
Again many thanks, ncbugeye will be happier soon.
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
maxwedge5281 front hubs for bolt on wheels Austin Healey 7
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
maxwedge5281 front pieces for bj7 hubs with bolt on wheels Austin Healey 8
maxwedge5281 wtb front drums for steel wheels Austin Healey 1
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
W TR6 TR6 front wheels Triumph 7
BoyRacer BJ8 front stub axles & hubs for bolt on wheels Austin Healey 0
bigjones Play in Front Wheels Triumph 31
K TR2/3/3A TR3 alloy wheels and Front suspension upgrades Triumph 14
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
