TR2/3/3A Rimmer Brothers Replacement Front Wing Quality?
1957BRGTR3
Has anyone purchased a replacement front wing for a TR3 from Rimmer Brothers? I'm curious what the quality of the stampings is and how difficult it is to fit. I purchased the replacement rear apron section from them last year and had a difficult time getting the spare tire cover to fit, I tried multiple covers, but modification was still needed to make them fit decently. I just want to get an idea before I spend $1100. The wing I have looks like it got in a fight with a Leyland bus and lost. Thanks, Trevor
Joel Lester
Hi Trevor,
I can't comment on the quality of the wing replacement but I can tell you that these cars are hand built and every single body piece that I've dealt with always seems to take a little fitting here and there. For example, I got a hard top for my TR3 and you would think that it just "bolts right on". I was really surprised at the amount of tweaking I had to do. And yes, even my back spare tire cover was kinda hard to get right. I guess it's just the nature of working on these beasts!
Good luck though.
Joel
charleyf
Hi Trevor,
I agree with Joel. My experience is that even used parts off of the original cars are often difficult to fit. About six years ago I bought a dog-legged panel ( fits behind the door on the TR3) from TRF. They warned me before I bought it that it was a poor stamping and fitting would be difficult. I only needed the lower 3-4" and felt like trying to duplicate the piece was not a good idea. Well they were correct. Fortunately it did give me enough shaped metal that I could then reshape what I needed.
During my restoration I had three rear fenders. The one that came on the car ( probably not original to this car) it was in very rough shape. I bought a used second one that had been worked on a bunch to fit the sellers car. I tested it on my car and it needed some reshaping to fit my car. Unfortunately that one was destroyed in a fire before I got to use it. So I found a used third one and still had a lot of work to get it to fit my car.
I suspect my car was as much of the problem as were the used parts that I bought. But getting used sheet metal to fit takes time and some skill.
Charley
GilsTR
Trevor. If you might consider a Original RF wing....
needing the usual patch panel... have one I am ready to let go.
Have box on hand....if you are interested.
(fraction of the repo price.) California part.
Gil. NoCal
CJD
The best parts are labeled as approved by "British Heritage", which seems to be a group in the UK who assures parts meet a minimum level of originality. Ask them. If they are not British Heritage approved, then my experience with Rimmer is their sheetmetal is not that good. I bought 2 seat pans that were just plain nasty. I had to send them to recycle, as they could not even be made to work after working on them for a week.
Jerry
I am not sure where RImmer buys their body parts. I did buy a fender from MOSS and it did not fit . I had to cut off the bolting strip and re-weld it on to line it up with the capture nuts on the car. As said above, they are not the same as original parts. But it was better than the fender I had which looked like 20 teenagers hit it with a sledge hammer for days. I think I have enough body work experience to get most parts to fit now. It would be very hard if I expected it to bolt right on out of the shipping box.
mctriumph
Suicide is where AM tr3 sheet metal will lead you, never consider either. Used is the only option,
they all have rust and dings. I have even delved into my trash pile and saved what I had previously
considered beyond all hope.If you find one that is pretty good CELEBRATE !! As a pro, even I have
spent as much as 30 hours on a tr3 front wing(X 60 $ per hr)
Mad dog
GilsTR
Trevor. Unsure if you need a RF. Or. LF fender.
I only have RF... yes needs patch panel.
But only $175+ actual shipping.... if interested.
Gil. NoCal
mctriumph
Trev, you should also be aware that the early fender (pre 60000) is slightly different
from the latter. Will work when given the proper massage, but is "off" at the lower front.
Mad dog
richie TR4/4A Rimmer Brothers TR4a Exhaust Triumph 3
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
HighAltitudeTR3 TR2/3/3A Any feedback on this? Rimmer Bros engine rebuild Triumph 6
Rut TR4/4A Rimmer interior Triumph 17
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
Scott_Hower Rimmer Bros sale ends soon... Triumph 2
TR6oldtimer Rimmer Bros Ltd Triumph 19
Scott_Hower Rimmer Bros sale... Triumph 4
PATR8 Wedge Where does one find a Rimmer Aley Bar for TR8 Triumph 13
G Anyone here from US ever bought from Rimmer Bros? Restoration & Tools 16
jerrybny Rimmer Bros Triumph 17
SpannerMan TR6 Rimmer Bros Vynide PVC Top/Hood cover TR6 Triumph 3
RichBall For our Brothers in the Portland area Spridgets 2
T Build log: 2 Brothers and a '59 Frogeye Spridgets 14
Randy Harris A couple of No. Calif. "Healey Brothers" Austin Healey 7
jackq 1926 Dodge Brothers Business Coupe Other Cars 14
L Any Brothers or Sisters out there? Austin Healey 4
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
D Engine replacement. Rover / Land Rover 0
EWD TR6 Dash Pad Replacement Triumph 3
