1972 Midget Seat Belt Replacement
Maraldo
Hi All - i've searched around a bit...i'm positive this was likely addressed in the past but i can't locate. Looking for replacement belts for a '72 Midget. Currently have the inertial reels mounted on the wheel well above the shoulder. Lot of conflicting info on what to buy...thoughts?
thanks!
Dave
JPSmit
M
Maraldo
They Carry them at Moss Motors. They are also the same as MGB belts.
I suspect you could also use a generic belt as well.
Thanks!! I was hesitant to buy since it was listed for a ‘73 and up…I take it I can use it on a ‘72?
JPSmit
Everything is pretty much interchangeable and and they typically changed and substituted parts during the years as old parts ran out and new regulations came in. I suspect the only change was to three point from two point so you should be good to go.
I suspect the only change might <might> have been a different sized latch so if you are buying a set it won't matter. The anchor points will almost certainly be the same.
M
Maraldo
Excellent!! Thank you very much for the advice!
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
M 1972 Midget Engine Issues Spridgets 10
M General MG 1972 Midget cylinder pitting MG 19
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
A 1972 MG Midget/Dragonfly Roadster MG 2
AngliaGT 1972-'79 Midget Parts Spridgets 7
L 1972 MG Midget...alignment MG 1
vping Can't believe I fit my 1972 Midget in.... Spridgets 18
spiny removing sppedo cable from gearbox [1972 midget] Spridgets 3
F 1972 MG Midget fuel pump MG 0
F 1972 MG Midget fuel pump Spridgets 10
I MGB Purchase of 1972 MGB Roadster MG 3
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
S MGB-GT 1972 GBT overheating MG 10
R MGB 1972 MGB Defroster Hose MG 2
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
C TR6 Ignition Switch for 1972 TR6 Triumph 1
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
tr6web TR6 No spark 1972 TR6 Triumph 35
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
W ash tray for a 1972 MGB, MG Classifieds 5
C 1972 Honda N600 Other Cars 4
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
JPSmit Spotted - 1972 Ambulance Other Cars 5
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D MGB-GT 1972 MGB Cloth Seats [Original?] MG 1
2 1972 TVR Vixen 2500 Radiator TVR 6
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
W TR6 1972 or 1973 TR6 Triumph 9
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
A TR6 1972 ignition buzzer Triumph 2
B Got permission to sell Audry's 1972 Clubman British Motor Corp 3
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
U New York City in 1972 Spridgets 18
B XJ-6 [1972] Emmision Problem Jaguar 4
B TR6 1972 TR6 with "A"OD, issue with shift cover Triumph 4
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
Psevins GT6 1972 GT6 Steering Column Triumph 3
B TR6 1972 tr6 orignality question Triumph 3
C Jackie Stewart's Tyrrell F1 Car [Monaco GP 1972] Racing 1
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
T 1972 tvr 2500 TVR 3
