1972 Midget Engine Issues
Maraldo
Hi...this is a repost on recommendation from the MG General Thread. Picked up a ‘72 midget ~2500 miles ago...ran beautifully...about a month ago, the fuel pump went...no issues replacing. The following week it started to ‘choke’ as i was driving...would bog down and then catch and run even again...this was an instantaneous event...happened three times across a 3 mile stretch of road and then just died. Rebuilt the carbs...pulled the shafts (felt like it was taking on air). Finally brought it into the shop...he pulled the plugs/gaskets and looked down the Cylinders...said two had no finish with significant pitting...80% by pass. His recommendation was finding someone to do the honing or replace the engine. I have checked the fuel system and the wiring...inspected the springs and the pistons. Mechanic still comes up with the pitting is causing gapping creating no utilization of 2/4 cylinders...and that engine is struggling to run on the other 2. Have known the mechanic for many years...trust is not an issue.. Thanks all!!
Boink
Bronze
And the compression in all 4 cylinders is ____________??? Too easy not to check.
When you report that he pulled plugs "and gaskets", what do you mean by pulling gaskets? Was the head removed?
All that written, given your description of its sudden nature, I'd also be looking at fuel and spark too.
pdplot
Look at the plugs to see what cylinder/s are not working.
Your fuel pump may be a loser. Check it out.
Your coil may be overheating.
You may have foreign matter in your gas tank closing off the fuel opening from time to time.
Remember the Old Mantra "If it's got gas and got spark and they both get there about the same time - it's got to run."
Bob Claffie is right. Start with the little obvious things before a teardown and rebuild - unless you were planning to do a major overhaul anyway. (We love these mysteries - it could happen to any of use, and probably will sooner or later.) Just be sure to follow through and tell us what it was when you find the problem.
SD Bugeye
So this pump you replaced it with. what is the pressure output.
anything more than 4 psi could be an issue
Joe Schlosser
Just mu two cents
Pitting causing loss of compression is not something that happens in 2 weeks. If it was running well and then all of a sudden stopped running well there should be another issue that you need to find.
Pulling everything apart tp fix the compression issue (you never mentioned the values) is fine but what is causing the problem will most likely still be there.
My rule is that it is the last thing you touched. In this case the fuel pump. Sucking air" not enough flow or too high a pressure? Why rebuild carbs before checking for other causes.
Carbs like cylinder walls do not just stop working.
When you said 80% by pass, it suggests that maybe he did a leakdown test. However, leakage can occur between cylinders (with a blown head gasket) or past valves. I would perform a leak down test again and listen carefully to identify wear the air is going (crankcase, intake, exhaust, OR nearby cylinder)
Trusting a mechanic to be honest doesn't mean that he is infallible.
Bob Claffie
Sounds to me like the original poster has his head made up and no matter what we suggest he is going to stick with his veteren machinist's idea. I wash my hands of this problem.
Boink
Bronze
Agreed. Many things to check (or eliminate)... milky coolant, leak-down, compression, condition of plugs, etc. (all easy to check).
In my own case, I had the dreaded head-blanking-plug recession problem which created a similar sputter (as there was leaking across the two middle cylinders - instantly obviously upon remove of the head). The sudden nature of the problem should be telling.
LarryK
Might even be something in the fuel tank. If it ran good to begin with, nothing wrong with engine.
Bob Claffie
Appears we will never find out the real problem or solution.
LarryK
:sorrow:
M 1972 Midget Seat Belt Replacement Spridgets 4
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
M General MG 1972 Midget cylinder pitting MG 19
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
A 1972 MG Midget/Dragonfly Roadster MG 2
AngliaGT 1972-'79 Midget Parts Spridgets 7
L 1972 MG Midget...alignment MG 1
vping Can't believe I fit my 1972 Midget in.... Spridgets 18
spiny removing sppedo cable from gearbox [1972 midget] Spridgets 3
F 1972 MG Midget fuel pump MG 0
F 1972 MG Midget fuel pump Spridgets 10
I MGB Purchase of 1972 MGB Roadster MG 3
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
S MGB-GT 1972 GBT overheating MG 10
R MGB 1972 MGB Defroster Hose MG 2
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
C TR6 Ignition Switch for 1972 TR6 Triumph 1
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
tr6web TR6 No spark 1972 TR6 Triumph 35
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
W ash tray for a 1972 MGB, MG Classifieds 5
C 1972 Honda N600 Other Cars 4
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
JPSmit Spotted - 1972 Ambulance Other Cars 5
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D MGB-GT 1972 MGB Cloth Seats [Original?] MG 1
2 1972 TVR Vixen 2500 Radiator TVR 6
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
W TR6 1972 or 1973 TR6 Triumph 9
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
A TR6 1972 ignition buzzer Triumph 2
B Got permission to sell Audry's 1972 Clubman British Motor Corp 3
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
U New York City in 1972 Spridgets 18
B XJ-6 [1972] Emmision Problem Jaguar 4
B TR6 1972 TR6 with "A"OD, issue with shift cover Triumph 4
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
Psevins GT6 1972 GT6 Steering Column Triumph 3
B TR6 1972 tr6 orignality question Triumph 3
C Jackie Stewart's Tyrrell F1 Car [Monaco GP 1972] Racing 1
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
T 1972 tvr 2500 TVR 3
