TR6 1972 TR-6 Fuel Vapor Recovery System
dhagerty
Have placed the fuel vapor recovery system into complete service on the TR-6. The lines to the carbs and the valve cover were in place, but the line from the fuel tank was plugged at the beginning of the steel line at the fuel tank end. Cleaned all that out and this line is now free to the carbon vapor collection tank. Have also installed the oil vapor recovery system by Good Parts (www.goodparts.com) and an electric fuel pump.
The diagrams call for an orfice (restrictor) in the vapor line from the fuel tank to the carbon canister. I cannot find one available from the parts suppliers so I made one with my 3D printer. Taking a shot at the level of restriction I put a 1.7mm hole in my unit. My question is "Does anyone know the size of hole (orfice) required for the restriction or is the restrictor constructed by another method such as baffles." I can 3D print almost anything so find out what was the original construction would really help.
If I get a good design I will put the STL file here on a post so anyone with a 3D printer, or access to one (friend) can print one out.
Thanks
Dean Hagerty
Tr6easyrider
Does this help Dean.
Measurement are in inches with digital caliper
Length= 0.508 in.
Large shoulder dia.= 0.438 in.
Small shaft dia.= 0.317 in.
Large hole depth= 0.362 in.
Large hole inside dia.= 0.195 in.
Smaller hole inside dia.= 0.095 in.
It is a snug fit into the canister.
TR6 1971 canister.
Tr6easyrider
Length= 0.508 in.
Small shaft dia.= 0.317 in. Has a small bevel on the end..
TR6 1971 canister.
dhagerty
These measurements are great. Yours fits directly into the vapor recovery tank, I am making mine to go into the line before the tank, as shown on the Moss and other parts diagrams. The key here is the inside measurement of the actual "pass through" hole that allows the vapor into the canister. This tells you how much vapor Triumph wanted to pass into the carb and thus the actual flow of "air" into the intake system. Will put the final design and measurements on the thread once I get a new one printed.
Thanks for the help.
dhagerty
Printed new orfice for the line. I noted some significant retuning of the carbs is now required due to the additional air being drawn into the intake manifold. The old vapor line was plugged solid (see above) and the carbs were tuned for the resultant reduced airflow. Today was the first time out with the new orfice and I had to keep some choke in place to have the car perform normally. I cannot attach the STL file as this system will not allow the file extension. If anyone wants the STL file drop me a note to dwhagerty@gmail.com and I will send you the file. This should work on any 3D printer but the particulars for the one I used are as follows:
Printer Prusa I3 Mk 3s, Sunlu PETG filament, .6 nozzle, .3 Quality build setting, 40% infill, requires supports.
The orfice hole is 2.4mm in diameter as this was based from the input provided by TR6easyrider.
If I have any updates will post them with this thread.
Dean
F 1972 MG Midget fuel pump MG 0
F 1972 MG Midget fuel pump Spridgets 10
I MGB Purchase of 1972 MGB Roadster MG 3
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
S MGB-GT 1972 GBT overheating MG 10
R MGB 1972 MGB Defroster Hose MG 2
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
C TR6 Ignition Switch for 1972 TR6 Triumph 1
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
tr6web TR6 No spark 1972 TR6 Triumph 35
M 1972 Midget Seat Belt Replacement Spridgets 4
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
W ash tray for a 1972 MGB, MG Classifieds 5
C 1972 Honda N600 Other Cars 4
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
M 1972 Midget Engine Issues Spridgets 10
M General MG 1972 Midget cylinder pitting MG 19
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
JPSmit Spotted - 1972 Ambulance Other Cars 5
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D MGB-GT 1972 MGB Cloth Seats [Original?] MG 1
2 1972 TVR Vixen 2500 Radiator TVR 6
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
W TR6 1972 or 1973 TR6 Triumph 9
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
A TR6 1972 ignition buzzer Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
B Got permission to sell Audry's 1972 Clubman British Motor Corp 3
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
U New York City in 1972 Spridgets 18
B XJ-6 [1972] Emmision Problem Jaguar 4
B TR6 1972 TR6 with "A"OD, issue with shift cover Triumph 4
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
Psevins GT6 1972 GT6 Steering Column Triumph 3
A 1972 MG Midget/Dragonfly Roadster MG 2
B TR6 1972 tr6 orignality question Triumph 3
C Jackie Stewart's Tyrrell F1 Car [Monaco GP 1972] Racing 1
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
T 1972 tvr 2500 TVR 3
Gliderman8 1972 Honda Z600 Coupe Spotted 21
W TR6 how to lowering 1972 TR6 soft top Triumph 4
S TR6 Hood insulation for 1972 TR6 Triumph 3
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
