Seems I have broken/jammed something on the shift rods.
When coming our of reverse the shifter jams up.
All gears run through OK.
In-addition, sometimes the transmission will jump out of reverse.
I don't drive this car hard at all.
Restored ground up in 2007. Transmission came with the car new and rebuilt once.
If I replace the cover is it the same as a standard 4 speed? Which I believe it's not.
Before I remove anything I would like to have all the parts there to reduce down time.
Can a standard 4 speed cover be modified if this is the case?
I appreciate any advice.
Thanks Arlie
Thanks Arlie
