TR6 1972 Blowing fuse fed by white wire
edkap2002
Yup...72 TR6 ....driving along and fuel gauge and temp gauge stop working....fuse was blown.....new fuse...blows again....I put in a 30 amp fuse....all seemed ok for a minute but then fuel gauge stops working, temp gauge stops, and now I smell something burning....and the wipers come on by themselves....sure enough...the wiper switch on the dash is fried.....Question: is it fair for me to assume that the wiper switch suffered the short which was causing the fuse(s) to blow int he first place.....Im hoping so because that is an easy fix.....thanks for comments and assistance....Ed
smaceng
No. The wiper switch may have fried because the current due to the short took the path of least resistance. You need to completely examine the wires behind the dash for damage. BTW: A 30 amp fuse (American style) is too large.....should be either 20A or 15A. American style. British use a different rating system for fuses. Don't power the wire circuit until you know that there is no direct short....use an ohmmeter.
Good luck
Scott in CA
edkap2002
edkap2002
Good luck
Scott in CA
Thanks for the good advice.....ill going to have my work and learning curve cut out for me!
Sarastro
Scott is right; you need to check the rest of the circuit and be sure that there is no short elsewhere. Might have been something in the switch, but easily could be something else. Also, you need to check for other damage that the overcurrent could have caused--burned or melted wire insulation, for example.
I guess I could make the point that inserting a larger fuse is not the optimum way to solve a fuse-blowing problem, but I think you know that now.
martx-5
Here's a link to the wiring diagram for your car. The circuit involved that is being fed by the white wire is the ignition switched circuit consisting of all of the green wires. In that circuit are the wipers, windscreen washer, temp & fuel gauges, heater fan, brake lights, turn signals, reverse lights and seat belt circuit. Any one of those circuits could be the problem, but the most likely suspect is the wiper switch and/or motor.
http://www.advanceautowire.com/tr2506.pdf
edkap2002
edkap2002
Thanks so much....grateful for help!
I MGB Purchase of 1972 MGB Roadster MG 3
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
S MGB-GT 1972 GBT overheating MG 10
R MGB 1972 MGB Defroster Hose MG 2
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
C TR6 Ignition Switch for 1972 TR6 Triumph 1
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
tr6web TR6 No spark 1972 TR6 Triumph 35
M 1972 Midget Seat Belt Replacement Spridgets 4
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
W ash tray for a 1972 MGB, MG Classifieds 5
C 1972 Honda N600 Other Cars 4
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
M 1972 Midget Engine Issues Spridgets 10
M General MG 1972 Midget cylinder pitting MG 19
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
JPSmit Spotted - 1972 Ambulance Other Cars 5
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D MGB-GT 1972 MGB Cloth Seats [Original?] MG 1
2 1972 TVR Vixen 2500 Radiator TVR 6
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
W TR6 1972 or 1973 TR6 Triumph 9
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
A TR6 1972 ignition buzzer Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
B Got permission to sell Audry's 1972 Clubman British Motor Corp 3
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
U New York City in 1972 Spridgets 18
B XJ-6 [1972] Emmision Problem Jaguar 4
B TR6 1972 TR6 with "A"OD, issue with shift cover Triumph 4
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
Psevins GT6 1972 GT6 Steering Column Triumph 3
A 1972 MG Midget/Dragonfly Roadster MG 2
B TR6 1972 tr6 orignality question Triumph 3
C Jackie Stewart's Tyrrell F1 Car [Monaco GP 1972] Racing 1
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
T 1972 tvr 2500 TVR 3
Gliderman8 1972 Honda Z600 Coupe Spotted 21
W TR6 how to lowering 1972 TR6 soft top Triumph 4
S TR6 Hood insulation for 1972 TR6 Triumph 3
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
HerronScott 1972 Warshawsky catalog Triumph 7
AngliaGT 1972-'79 Midget Parts Spridgets 7
