TR6 1972 or 1973 TR6
whiterockdoc
My serial number is CF2347 and I believe it was built in 1972. Not sure if this is a 1973 car, built in 1972, or is it a 1972??????
Tybalt
The CF prefix indicates that it is a 1973 model carb spec car. The prefix CC was used on carb spec cars for the 1969 through 1972 model years. The production survey information that I have shows that there was an overlap of about 20 days when both CC and CF series cars were produced covering mid September through early October. If we operate on the assumption that the production date information posted above for CF2365U, your car was also produced in October of 1972. Taking a proportional number of days from the date of CF1U build and with CF4029U being the first CC series TR6 built in 1973, no more CC series cars on the line after early October, thinking about holidays and all that plus the chassis number of the first TR6 built in the 1973 calendar year, I'd guess that it was rather late in October for the build date. As for using the CR series car above, you can't really do that to try and date production of your car since the CP and CR series of PI cars changeover dates differ and they carried their own list of serial numbers with CR6701 being the last PI car produced in early 1975 while the last of the TR6s (CF58328U) was built in mid July of 1976.
Looking at the CR series car linked and thinking about the serial number of the first CR series car produced during calendar year 1973 and the date the last 1973 model year CR series car was produced, the indicated BMIHT build date listed is right in line with any guess I would have made regarding build date using number of cars and number of working days to make that guess. Since that car carries an "O" suffix, it is/was originally fitted with an overdrive transmission.
As for the "U" suffix used for calendar year 1972 and up vs the "L" suffix used for calendar year 1971 back, I believe that the "L" was used to designate left hand drive cars going back to the TR2/TR3 days with no letter designation being used for right hand drive cars. BMC on the other hand had a habit of using "U" as a designation in their serial numbers and I can't help but wonder if the change was a reflection of all the bits that came together to form British Leyland entering into the mix.
M_Pied_Lourd
I owned CF102UO at one point...1973. I own CF4874UO currently, also a 73.
Cheers
Tush
poolboy
I realize they might not be original, but the carbs they put on the 73 cars were unique, unlike any other year.
If you could post a picture showing the left side of the carbs, I could tell you if they were 73 carbs or not.
poolboy
1973 was the first year for the Anti Run-on Valve and the mechanism attached to the carbs was unique to that year.
They did not have it prior to 73 and it was changed in 74 and remained in that configuration until the end.
mgedit
My 73 is CF727U ... so your one sounds like a 73 to me. Cheers, Mike
M_Pied_Lourd
According to my heritage certificate, CF4874UO was built on Jan 23, 1973.
Cheers
Tush
I MGB Purchase of 1972 MGB Roadster MG 3
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
S MGB-GT 1972 GBT overheating MG 10
R MGB 1972 MGB Defroster Hose MG 2
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
C TR6 Ignition Switch for 1972 TR6 Triumph 1
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
tr6web TR6 No spark 1972 TR6 Triumph 35
M 1972 Midget Seat Belt Replacement Spridgets 4
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
W ash tray for a 1972 MGB, MG Classifieds 5
C 1972 Honda N600 Other Cars 4
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
M 1972 Midget Engine Issues Spridgets 10
M General MG 1972 Midget cylinder pitting MG 19
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
JPSmit Spotted - 1972 Ambulance Other Cars 5
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D MGB-GT 1972 MGB Cloth Seats [Original?] MG 1
2 1972 TVR Vixen 2500 Radiator TVR 6
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
A TR6 1972 ignition buzzer Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
B Got permission to sell Audry's 1972 Clubman British Motor Corp 3
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
U New York City in 1972 Spridgets 18
B XJ-6 [1972] Emmision Problem Jaguar 4
B TR6 1972 TR6 with "A"OD, issue with shift cover Triumph 4
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
Psevins GT6 1972 GT6 Steering Column Triumph 3
A 1972 MG Midget/Dragonfly Roadster MG 2
B TR6 1972 tr6 orignality question Triumph 3
C Jackie Stewart's Tyrrell F1 Car [Monaco GP 1972] Racing 1
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
T 1972 tvr 2500 TVR 3
Gliderman8 1972 Honda Z600 Coupe Spotted 21
W TR6 how to lowering 1972 TR6 soft top Triumph 4
S TR6 Hood insulation for 1972 TR6 Triumph 3
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
HerronScott 1972 Warshawsky catalog Triumph 7
AngliaGT 1972-'79 Midget Parts Spridgets 7
