MGB-GT 1972 GBT overheating
bobhustead
Are you new to the car or is the condition new to the car? Assuming you are staying full of coolant, common problems include a bad thermostat, bad radiator cap, loose fan belt, dirty radiator core, poor air circulation thru the radiator fins. Does it cool properly at speed?
Bob
S
strategiclynk
Hi Bob it does cool properly on the highway
Not new to car, radiator is new, the thermostat/and switch is new and the water pump is new
The fan is constantly spinning, is that normal
Platinum
What year is this car? Electric fan?
Platinum
What brand water pump did it get? If it was one with a pressed steel impeller, it cavitates. Only the "Gold Seal" and "Heritage" pumps work as they should. We're in the Tampa Bay area and our MGB can sit in July traffic all day with no issue. Aluminum radiator, Gold Seal pump, electric "pusher" fan and 72°C (160°F) 'stat.
Platinum
So it seems air moving through the rad while under way keeps the temp down, indicating the t'stat and radiator are doing their job. At a stop, it seems the pump/fan are inefficient. The fan is mechanically connected to the pump and, yes, should be spinning constantly while the engine is running. Belt tension is a variable, as is which pump you got from the supplier. And you stated something about a "switch"? What switch is that? Not aware of any switch before 1977 models.
Dealing with sixty year old British cooling systems never designed to operate here in our climate/conditions, means every component needs to be in top shape. Again asking what brand water pump was fitted. If it is one with a stamped steel impeller, not a cast metal one, it will be inefficient.
In case you haven't seen this PDF from Moss Motors: The reason I question what pump was fitted. The "Gold Seal" pumps are the only ones we've fitted to any MGB coming into our shop with pump issues, for years. The stamped steel impeller ones are junk-out-of-the-box, AFAIC.
Just trying to narrow down possible causes, another question is how the fan is mounted. The '72 version should be metal with six blades and it can be mounted backwards... can you post a photo of the front of the engine showing the fan and pump?
Joe Reed
What DrEntropy is getting at is that the fan blades are not flat....they are curved. The fan can be installed backwards and still look 'kinda" correct if you don't look close. As the fan turns the curve of the blades sorts of scoops the air from the radiator towards the engine. Think about how you curve your hand if you want to scoop some water. If the blade is backwards the curve faces the other way.....sort of like if you tried to scoop water with the back of your hand.
The difference isn't usually noticeable while the car is moving at any speed since the volume of incoming air forced through the radiator is far greater that what the fan can move. At idle, or even very low speeds, the inefficiency of the backwards fan becomes apparent.
JPSmit
The other thing I might add is whether the rad itself is clogged or bocked. You might be able to tell fif you had a laser thermometer - maybe <maybe> even judiciouly touching the rad at different palces when hot to see if the heat is uniform.
Platinum
JP. the initial description was the radiator and thermostat are "new", so I've assumed that to be so. That it goes to normal temps when driving would indicate the block is clear enough, so not much left except poor belt tension, fan on backwards and/or cheesy pump.
I'd like to think we'll get a follow-up post from Strategiclynk.
JPSmit
doh! missed that
I MGB Purchase of 1972 MGB Roadster MG 3
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
R MGB 1972 MGB Defroster Hose MG 2
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
C TR6 Ignition Switch for 1972 TR6 Triumph 1
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
tr6web TR6 No spark 1972 TR6 Triumph 35
M 1972 Midget Seat Belt Replacement Spridgets 4
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
W ash tray for a 1972 MGB, MG Classifieds 5
C 1972 Honda N600 Other Cars 4
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
M 1972 Midget Engine Issues Spridgets 10
M General MG 1972 Midget cylinder pitting MG 19
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
JPSmit Spotted - 1972 Ambulance Other Cars 5
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D MGB-GT 1972 MGB Cloth Seats [Original?] MG 1
2 1972 TVR Vixen 2500 Radiator TVR 6
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
W TR6 1972 or 1973 TR6 Triumph 9
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
A TR6 1972 ignition buzzer Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
B Got permission to sell Audry's 1972 Clubman British Motor Corp 3
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
U New York City in 1972 Spridgets 18
B XJ-6 [1972] Emmision Problem Jaguar 4
B TR6 1972 TR6 with "A"OD, issue with shift cover Triumph 4
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
Psevins GT6 1972 GT6 Steering Column Triumph 3
A 1972 MG Midget/Dragonfly Roadster MG 2
B TR6 1972 tr6 orignality question Triumph 3
C Jackie Stewart's Tyrrell F1 Car [Monaco GP 1972] Racing 1
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
T 1972 tvr 2500 TVR 3
Gliderman8 1972 Honda Z600 Coupe Spotted 21
W TR6 how to lowering 1972 TR6 soft top Triumph 4
S TR6 Hood insulation for 1972 TR6 Triumph 3
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
HerronScott 1972 Warshawsky catalog Triumph 7
AngliaGT 1972-'79 Midget Parts Spridgets 7
