MGB Looking for best info regarding throttle cable replacement.
Celtic 77
Hey all, I am looking for the best way to install a throttle cable on my 77 B. Could be the cause of a fast or fluctuating idle?
JagConsult2
probably NOT the cause of idle fluctuation. the cable shpuld have a wee bit or free play when installed and secured to the throttle bracket. Quite possibly a slight vacuum leak created the idle fluctuation, snug the manifild and carb bolts when the car is cold.
Celtic 77
Celtic 77
Thanks for that.. Will try as soon as I fiddle with the other stuff that my beast seemed to stored for years.!
JPSmit
easiest way to check is to disconnect the cable at the carb. probably easier with a second set of hands, but, if the idle is erratic without the cable connected your issue is elsewhere.
JPSmit
and if I can make one more suggestion - loosen the cable but don't remove it - just let it slide. The ends tend to get a bit frayed making it very hard to reinstall. Don't ask me how I know. :rolleyes2:
Platinum
What carb(s) are you dealing with? The cable disconnect *may* give some insight but a spray bottle with water, engine up to temp, spray around all the intake joints around the manifold and note any changes in running at idle would be my "first step". That will indicate if/where a vacuum leak exists.
Platinum
as an aside question, wher/how can I get a longer accel cable for a cross flow head?
Have a look at bicycle brake cables. Different lengths and many are Teflon lined and smoother than the usual replacements from LBC parts suppliers.
drooartz
We did this on a friend's GT when the cable snapped on a road trip -- just happened to stop right across from a shop that had bike parts. Bought a 2-pack and she had a spare. Far as I know the car is still using that bike cable.
My Morris has a generic cable, possibly from a hot rod shop or Summit Racing (can't remember). Needed something different than stock due to my setup, it works great.
Celtic 77
Celtic 77
The awesome Zenith-Stromberg
JPSmit
I could never get my ZS to run right - in part because I understand that it really likes to have all the original gubbins - original air filter, all the pollution stuff etc. etc. The carb also has a water choke that almost always is broken by now. On mine, (Midget) I finally put an SU carb on it with a manual choke and the car was ever so much happier.
Platinum
Platinum
If you do decide to rebuild it or want it done by someone familiar with 'em, Joe Curto's outfit is top-of-the-list for parts or rebuild service. And they're almost next door to you.
Celtic 77
Celtic 77
All this info is greatly appreciated, and I think I have finally narrowed it down to electrical...per a well-respected MG/Triumph restorer and mechanic here in NJ. He's taking the car in to evaluate it and give me list of priorities from a safety standpoint. The car starts and runs smoothly then after no more than 1/2 mile starts to break and stumble slightly. Then time to nurse it home. Time for a pro!
J BEST LOOKING COUPE? Jaguar 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
C Looking for SoCal restoration shop Austin Healey 4
