Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
i plan to fix my brakes this week...
they work ok, but the pads are wore out....
i ordered 2 clips, 4 retaining pins,
new bleeders, and i already have pads and new
hoses........
other than fluid, did i forget anything?
....zzzimmmy
If they are even still there zimmy....be carfull when removing them, might be able to re-use. wont really hurt anything if you dont re-use or install new ones. I would use the antisqueal stuff either way. and that should be avaiable at any parts/chain store.
I recently redid my front brakes and decided on getting caliper rebuild kits and a couple new pistons as two of mine were badly pitted. You never know what your going to find until you open those calipers up.
i did my calipers, and it is pretty straight forward. takes longer to dissassemble and clean, than to reassemble. i used air to pop the old cups out, a grease gun would probaly work as well if you can get it to seal well. Be sure both halves are very clean where they mate together, use new seals. and as far as how tight the bolts should be....well i wasnt aware of this forum when i did mine so i tightned them to what i felt was appropriate (elbow torque). havent had any problems in 3 years. guess i am just lucky
thanks for ur confidence jack ; ) haha
im not doin them so far cause i didnt
order the parts...but who know what
ill find when i pull them for the pads....
maybe ill get motivated and go see before
it get toooo hot ; ) .....z
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
