TR2/3/3A TR3 front disk brake squeal cause?
CraigLandrum
First test drive in the newly restored TR3 and we are working out the
little kinks. Car runs fantastic. Only problem so far is that the front right
brake squeals when applied. All of the brakes (disks and drums are running with new shoes, pistons, everything. Haven't attacked the problem yet but suspect it might be as simple as a need to rebleed. Could some air in the line cause this? Sort of makes sense that if there were some air in the calipers that one piston might be actuating while the air in the other is being compressed, causing one side to apply more pressure than the other, perhaps resulting in a squeal. Is that logic sound?
I know this is trivial and I should simply rebleed and be done with it but wanted to know if anyone has experienced the same thing.
After we tweaked the timing the car runs like a scalded dog. I swear this thing is faster than any of my previous 6 cyl big Healeys.
Will post some pics of the finished car in the next few days.
TR3driver
Great Pumpkin - R.I.P
I don't think so. Except when the fluid is flowing, the pressure is the same throughout the system. So there might be a small differential in the first fraction of a second after you hit the pedal, but not long enough to notice.
That said, I don't know how to stop the squeal. The only thing that worked for me was some aftermarket anti-squeal shims of soft aluminum. Cut them with scissors and stick to the back of the pad where it hits the piston. But others have reported that it didn't help them.
Don Elliott
This question just appeared on the forum for the TR Register and what the TR4 owner found was that one rotor had been turned by some previous owner below the lower thickness limit. He changed the rotor and solved his problem. Check the thickness of your rotors.
It may be that your new pads need time to "bed in".
You could try swopping the pads around later if it still happens.
Geo Hahn
I had a squeal that I addressed by using semi-metallic pads (from Moss) that were guaranteed not to squeal and also used some of that blue goo that is supposed to prevent squeal. One or both fixed the problem (I know, not a very scientific approach).
6TTR3A
Same as Geo Hahn
I had the squeal after installing brake pads from NAPA. Tried the blue goo; some help...broke down & bought the Moss pads w/o the blue goo...improvement...redid the blue goo..SOLVED!! (That was 2000 mi. ago)
Frank
bgbassplyr
You might try pulling the pads and beveling the bottom (leading edge) of the pad with a file, belt sander, or grinding wheel so that you eliminate the sharp edge of pad vibrating against the rotor.
Jim
rlandrum
Just some clarification... These are brand new rotors and pads. I believe the pads are "mean green". Rotors were Moss, I believe.
rlandrum
Also, as I recall, my Father said it was pulling to one side, which suggests it more than just a noise problem.
TR3driver
Squealing brakes frequently do pull; I'd solve the noise first and then see if they still pull. They also wear out faster.
Don Elliott
For the first 43,000 miles from new, I swopped the inboard and outboard pads on the front brakes on my 1958 TR3A several times because the pads were not all wearing the same. I was swopping them on the same side, then onto the other side. The inboard pads were wearing a lot faster that the outboard pads which is logical. Maybe I had a heavy foot back then. At 43,000 miles I put in new pads and they did not show this problem at all. And this second set of front rotor pads lasted till the mileage was up to 174,000 miles.
trfourtune
Bleed them again if they pull. Then apply the blue goo to the back of the padS and let it set up a little. Install pads and very lightly apply the brakes-just enough to put pressure on the pads. Let sit overnight.
Now go out and drive the car and make progressive stops from increasing speed and pressure (say 15 stops-last significant one from high speed to 10mph-at no time should you stop and sit with the brakes appied) then go home and park. Let sit for 2 hrs then go for a drive and see how they are.
Squeel is usually from vibration of the back of the pads against the caliper pistons.
R
CraigLandrum
CraigLandrum
Thanks for all the suggestions - will look at them this Saturday when we hope to have some sunshine here in VA.
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
T TR2/3/3A tr3 front carpet replacement Triumph 5
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
S TR2/3/3A tr3 front apron body work Triumph 9
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
S TR2/3/3A tr3 front fender Triumph 4
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
luke44 TR2/3/3A TR3 Front Fender Washers? Triumph 19
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
T TR2/3/3A TR3 front license plate Triumph 4
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
BillyB62 TR2/3/3A Front Float Cover Lid for TR3 H6 Carb Triumph 10
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
Kleykamp TR2/3/3A TR3 Front Emblem??? Triumph 7
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
Tr3aguy TR2/3/3A TR3 Front suspension breakdown..Help Triumph 2
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
O TR2/3/3A TR3 front End Alignment Triumph 8
B TR2/3/3A Fitting the front wing 57 TR3 Triumph 2
B TR2/3/3A Installing front fenders on TR3 from TRF Triumph 12
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
S TR2/3/3A front bumper override tr3 Triumph 6
S TR2/3/3A tr3 front end alignment Triumph 9
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
B TR2/3/3A Tr3 removing front wings Triumph 8
O TR2/3/3A TR3 Headlite Trim Rings and Front Parking Lite? Triumph 10
R TR2/3/3A TR3 Front Suspension and Steering Triumph 12
