TR2/3/3A 1960 TR3 Front Brakes
oxendine
After closer examination of my front brakes I discovered there was no pin to hold the pads in place. One of them was about to fall out. VB lists them for my car, Moss does not. Is there any other option to use? Long cotter key or something else? I haven't pulled of the right side yet but I'm betting the dpo did not install that side correctly as well.
martx-5
Another source is The Roadster Factory. They list a pad and pin kit...RFK605. Any pin could be used that fits the hole, is long enough and has two holes (one on both ends) for a small cotter pin fitment so the pin doesn't fall out. Long cotter pins would work also, as they were used on early Saab disc brakes. The pins are only there to hold the pads in.
Edit: Another alternative is go to your local FLAPS and see what they have. Should be able to find something close. Even if it's longer, you can always cut to length and drill another hole.
TR3driver
Great Pumpkin - R.I.P
Apparently your car has calipers from a later car. The original calipers for a 60 TR3A used plates and bolts to retain the pads instead of pins. VB has them listed because they fit a 62 TR3B (which used the later calipers) and they don't know the difference.
Moss has the pins, PN 582-020. TRF has them as PN 509058.
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Pool Dad 1960 TR3 engine serial number Triumph 14
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
pbraun TR2/3/3A 1960 TR3 photos Triumph 17
Tinkerman TR2/3/3A Bonnet stay rod 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A Original wind screen 1960 TR3 A [free to a good home] Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
Tinkerman TR2/3/3A 1960 tr3 a to gasket or not to gasket Triumph 35
Tinkerman TR2/3/3A 1960 tr3 a upholstery question Triumph 2
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
Tinkerman TR2/3/3A 1960 TR3 A Hood stick mounting point? Triumph 11
Tinkerman TR2/3/3A Apron installation 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A 1960 tr3 a carpeting the floor Triumph 8
Tinkerman TR2/3/3A 1960 TR3 A hood stick color? Triumph 2
Tinkerman TR2/3/3A Windshield glazing TR3 A 1960 Triumph 7
Tinkerman TR2/3/3A Wind scereen support bracket tr3 a 1960 Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
R TR2/3/3A 1960 TR3 Restoration Triumph 8
Tinkerman TR2/3/3A 1960 TR3 Post 60000 elec equipment Triumph 12
boxofparts TR2/3/3A Dads TR3 way back in 1960 Triumph 16
J TR2/3/3A New Member 1960 TR3 Triumph 11
L TR2/3/3A 1960 TR3 cooling???? problem Triumph 9
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
