TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs
MKN
before swapping in the 8 new studs, any advice on best way to clean out chamber to ensure proper seating? solvents? WD 40? simple 1/2 inch bottle brush and/or clean rag? compressed air (as in computer or keyboard use)?
if more than one step, any specific order? Thanks
Popeye
Bronze
Ditto on John - but brake cleaner works well. (Use in ventilated area, wear nitrile gloves, etc. - nasty stuff.)
Note, it will clear any protecting oil... if you do not plan on running the motor for a bit, rust moves in quickly. Helps to smear / fog oil on metal surfaces. Especially in humid Florida. (I will be jealous in January!)
sp53
To clean the combustion chamber and areas around it use carburetor cleaner in a spray bottle; it will clean all the carbon out and will not hurt anything. There is no rubber anywhere in there to hurt. One can will do the whole head.
steve
W For Sale 1960 TR3A for sale Triumph Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
Tinkerman TR2/3/3A 1960 TR3A carpet installation Triumph 5
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
Tinkerman TR2/3/3A Prepping the grill for installation for my 1960 TR3A Triumph 1
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
Tinkerman TR2/3/3A Tunnel installation question 1960 TR3A Triumph 11
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
Tinkerman TR2/3/3A Carpet underlayment, TR3A 1960 Triumph 10
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A seat tack strips Triumph 1
Got_All_4 TR2/3/3A Finish on a 1960 TR3A Fluid reservoir? Triumph 6
60TR3A TR2/3/3A 1960 TR3A Small Mouth [Huh?] on eBay Triumph 63
M_Pied_Lourd TR2/3/3A 1960 TR3A Mystery G Triumph 24
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
M_Pied_Lourd TR2/3/3A Restoration of TS 69891LO 1960 TR3A Triumph 36
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
PAUL161 TR2/3/3A Colonal Tom Parkers 1960 TR3a For Sale! Triumph 3
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
D TR2/3/3A 1960 TR3A Paint Question Triumph 24
gubba TR4/4A 1960 TR3A with tr4 motor and tranny? Triumph 22
D TR2/3/3A 1960 TR3A Flasher Triumph 7
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
