TR2/3/3A 1960 tr3a sheet metal fitment
Tinkerman
So, at long last, I have all of the sheet metal hung on my 1960 TR3A. This is a frame off, long term project and I can finally see the light at the end of the tunnel, yea! I get the feeling though, that I can't just start tightening all of the body bolts, I suspect that there is a right way and a wrong way to go about getting everything aligned and tightened down. So, my question is where do I start and how do I go about finishing up the body mounting with a minimum of mistakes, re-starts and do-overs?
Your thought, tips and suggestions are greatly appreciated!
Thanks, Tinkerman
CJD
Doors first. Set the rear gaps with the quarter panels.
Next front wings, setting the gaps with the doors, but not front bolts, yet.
Bonnet, setting the gap to the scuttle.
Front apron, setting the gap to the front of the bonnet.
Front bolts on front wings to inner wings.
Now for the rear...
Wings...tighten the 3 vertical bolts at the rear valence to align with the valence panel.
Work forward on the rear wing, one bolt at a time, aligning with the edge of the boot frame and rear scuttle.
Finish with the rear boot, aligning the gaps evenly on all 4 sides.
This sounds easy, but it is far from it. Each panel will take untold effort to align with the previous. The fitment is easier with lots of beer.
Kleykamp
Dick, I'm sure everybody has there "preferred" way to do it and it will require some tweaking as you go thru, but I prefer to have the doors off when mounting the front fenders because of better access to the vertical line of bolts at the hinge pillar. I also like to have the apron on prior to front fenders to avoid having to "sqeeze" the apron between the fenders. I just feel this way presents less chance of chipping paint. Use masking tape around the areas where panels are joined. Better to scratch the tape than the paint. You can be successful in any order, so I'm not disagreeing with John, but I think putting the fenders on with the doors on would be problematic. Maybe he means to align doors to quarters then take them back off. IDK
charleyf
And don't forget NOT to tighten up the fender bolts until you have the chrome fender beads in place. All six of them.
Charley
Tinkerman
Tinkerman
Thanks for the info. I feel a major do over coming on, sigh.......................................
I have to do this alignment with the wheels on and the car on a smooth surface. I would guess that the wheels should all have the same tire pressure and all of the body bolts need to be loose.
Cheers, Dick
Kleykamp
I think you're over thinking it. The biggest issue is if the body tub is located properly to start with. That establishes 90% of the panel alignment. There is very little adjustment built in to the body panels short of a 2x4 and BFH. To achieve those perfectly matched gaps would require trimming and welding of panels and test fitting prior to paint. That was just not a goal they strived for when the cars were built new. I understand that many people have that goal on a restoration and I admire their effort, but I think you are beyond that point now. If I recall you have the car painted already. It's not going to matter if one tire has 32 lbs and one has 35 lbs except in suspension alignment and ride height, which has nothing to do with body panel alignment. The frames are pretty rigid, but you'll have to take the wheel off the front to access the bolts to the apron. You just need to have it as level as possible even if its on jack stands.
sp53
I would suggest when you tighten up the bolts with the large fender washers inside the wings, front and back to make sure the fender washers themselves are not too large. If the fender washer is too large when you pull the bolt in the higher arch on the circumference of the large washer will push and pooch out the fender about a 1/16 or so. The original washers are not ¼ American size fender washers they are smaller. What happened to me on a couple of them was as I jockeyed the fender around with some of the bolts and washer and caused a dimple. The last time I did this I took an original washer with me to a bolt store and got something with a little bigger hole for the bolt and a little small diameter so it would not dimple the fender as it pulled in. I think Moss sells the correct washers. It does not matter on the front wing tops because there is room, only up the sides.
steve
W For Sale 1960 TR3A for sale Triumph Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Tinkerman TR2/3/3A 1960 TR3A carpet installation Triumph 5
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
Tinkerman TR2/3/3A Prepping the grill for installation for my 1960 TR3A Triumph 1
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
Tinkerman TR2/3/3A Tunnel installation question 1960 TR3A Triumph 11
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
Tinkerman TR2/3/3A Carpet underlayment, TR3A 1960 Triumph 10
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A seat tack strips Triumph 1
Got_All_4 TR2/3/3A Finish on a 1960 TR3A Fluid reservoir? Triumph 6
60TR3A TR2/3/3A 1960 TR3A Small Mouth [Huh?] on eBay Triumph 63
M_Pied_Lourd TR2/3/3A 1960 TR3A Mystery G Triumph 24
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
M_Pied_Lourd TR2/3/3A Restoration of TS 69891LO 1960 TR3A Triumph 36
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
PAUL161 TR2/3/3A Colonal Tom Parkers 1960 TR3a For Sale! Triumph 3
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
D TR2/3/3A 1960 TR3A Paint Question Triumph 24
gubba TR4/4A 1960 TR3A with tr4 motor and tranny? Triumph 22
D TR2/3/3A 1960 TR3A Flasher Triumph 7
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
