TR2/3/3A Tunnel installation question 1960 TR3A
Tinkerman
I'm happy to say that I now have tunnel bolted (loosly) to the top three bell housing bolts. I'm un-happy to say that while the driver side lip is flat on the floor, the passenger side is not!
Major problem? Minor problem? Operator error? All of the above?
I might add that the floor is new and the only thing on the floor is a layer of heat and noise reduction material, about .25 inches thick.
Your thoughts and comments greatly appreciated!
Tinkerman
Tinkerman
Tinkerman
Drivers side is flat passenger side at the bell housing is about 1" and just aft of the hand brake is about 1/2'
Dick
TexasKnucklehead
Dick,
The floor pans are not difficult to bend around. You can use a floor jack with a 4" length of 4x4 (that would be a 4x4x4) to push the floor up toward the tunnel. Thread a half inch or so of each bolt starting at one end -probably the end toward the front of the car because the last two bolts near the drive shaft tunnel are the hardest. Once the first ones are started, lower the jack and move the 4x4x4 to the next one to align it. You don't want to raise the whole car by the floor pan, but you will be amazed how much it will move. The tightened tunnel bolts will hold the floor pan in position when you are done. I took some larger (over 1") fender washers and bent them 90 degrees off center to allow each bolt a better grip onto the tunnel. -The pointed bolts are helpful too.
Tinkerman
Tinkerman
Thanks for the info. I loosened up the body bolts I have going into the bell housing and was able to turn the tunnel enough to even out the spacing. It looks much more doable now. I feel that I'm
just tantilizing close to getting it allmost all there. It is also helpful to having a goodnight sleep and then returning to the little problems and find the answer was right there all the time. I have several 4X4's hanging out just waiting for a project. Sounds like I will be useing them to get it all going right. I have to drill new bolt holes because my new floor pan had none. Not a problem though.
Thanks, Dick
Crankshaft
One of the few good habits I have is to start all the bolts of a group and then go back and tighten them after all have'been started. Alway's helps the wiggle room.
Tinkerman
Tinkerman
Yep Phil, you are dead on with that. I usually do that but I just didn't do it , tired or brain dead one or the other or both, heh.
Thanks, Dick
CJD
These cars are definitely "alive", with personalities. I had my tunnel fitting flawlessly when I was doing the body work. I removed it to paint. But then it took hours to get it put back on. There is no explaination, except the car wanted to teach me a lesson. One more beer and I'll figure out what that lesson is...
PeterK
A trick I've heard is to thread bolts up through the floor pan from below to create studs to align the tunnel. Then remove and put each one back in from above after you get it aligned.
Never actually tried it but sounds good.
S Jute Installation on Transmission Tunnel - Heritage Trim Austin Healey 9
EWD TR6 Transmission tunnel insulation Triumph 6
nevets question about tunnel fastners Austin Healey 4
T TR6 two piece gearbox tunnel Triumph 5
T TR2/3/3A Transmission Tunnel Configuration Triumph 11
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
D Looking for Rubber Tunnel cover Spridgets 7
oxford tunnel carpet question Austin Healey 4
nevets Transmission tunnel removal Austin Healey 4
T BN-1 to Bn-2 Transmisstion Tunnel Help Austin Healey 8
J TR2/3/3A Transmission tunnel gasket? Triumph 16
F Seal between transmission tunnel and the forward bulkhead Austin Healey 7
MikeAH100M Transmission Tunnel Install - BN2 Austin Healey 2
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
D MK1 Rubber Tunnel Cover Spridgets 3
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
B TR2/3/3A After a beating, the tunnel still lives Triumph 6
B TR2/3/3A Beat my transmission tunnel to death? Triumph 12
T TR4/4A Cutting an access panel into transmission tunnel cover for solenoid adjustment Triumph 13
nevets Removing carpet from transmission tunnel Austin Healey 15
D BN2 gearbox tunnel cover Austin Healey 1
F TR4/4A TR4 shifter and transmission tunnel Triumph 4
mgbmedic TR2/3/3A TR3 Transmission Tunnel Triumph 8
rlich8 TRouble with the TRans tunnel and Speedo Pinion Triumph 4
rlich8 I need a GOOD fitting trans tunnel Triumph 14
jdubois My 308 restoration is nearing end of the tunnel! Other Cars 23
britndablood Need a pic of the trans tunnel front extention Austin Healey 3
stretchit2 Tranny Tunnel - Heated Opinions Austin Healey 17
eschneider Spitfire Spitfire ABS transmission tunnel cover - worth it? Triumph 10
pjsmetana Ok, Tranny Tunnel is Off... Triumph 14
A Wind Tunnel Austin Healey 8
L Not impressed with the tranny tunnel carpet Austin Healey 33
HealeyPassion Tunnel modifications for 5-spd conversions Austin Healey 15
M Transmission tunnel removal Triumph 14
jvandyke oil from the tunnel and more Spridgets 20
Steve1970 Tranny Tunnel Knocking Triumph 5
chicken how do you secure the transmission tunnel down ? Austin Healey 19
J Transmission Tunnel Cover - BN7 Austin Healey 10
C Transmission tunnel carpet Austin Healey 2
T TR4/4A Hmmm, Cardboard Tunnel for Rad - 4A Triumph 12
PHerder Never know what you will find in the trans tunnel! Spridgets 14
regularman Has anyone ever done any wind tunnel tests.. Spridgets 22
tony barnhill '85 XJ6 Switch Panel/Trans Tunnel Console Jaguar 9
CCURTISS TR2/3/3A TR3 Transmission Tunnel Sealant Triumph 7
vette Trans Tunnel Floor Flange Austin Healey 3
Ed_K Don't use RTV to seal the transmission tunnel Austin Healey 28
Jayrz Through Tunnel Exhaust Spridgets 18
C MGB Console tunnel - 1977 - 1980 MGB MG 5
G TR2/3/3A TR3 Tunnel cover Triumph 12
