chicken said:
Roger
I see you have lined the inside of your tunnel cover, is this for heat or noise ? is it worth doing ?
Rob
Hi Rob,
Is it worth doing? Absolutely! For heat.
Reducing the heat in our Healey's is like a chain. Find all the links and make sure they don't let the heat in, or reduce the amount of heat as much as possible. From holes in the firewall, under our drivers seat from the muffler, from the headers in the footwell and from the transmission. All these areas should be plugged, sealed or some sort of heat shield applied or improved.
The transmission tunnel.
Most importantly it has to be sealed. We've touched on that in this post already. Seal the bottom lip, the front and the rear. Keep that heat from entering the cockpit. Check the rubber shift boot. Don't think much heat comes in from there? Remove it and you'll have a hand warmer on a cold day, or a hot day.
The idea of putting a head shield on the bottom of the transmission tunnel is to reflect the heat. Keep the tunnel cool. What I used, others use other products, was a adhesive backed, thin aluminized heat barrier. The product is by Pegasus. Here's a link:
https://www.pegasusautoracing.com/productselection.asp?Product=1828
What ever product you use on the bottom of the tunnel, make sure the heat there will not melt the adhesive or any of the product is made of. Example would be Dynamat. The black material will melt. And you don't want that dripping onto the drive shaft or anything actually. Don't use that type of product.
On the top of the tunnel, I use another heat reducing product that also acts as a sound damping product. It is a type of closed cell product that also has a heat reflective product on both sides. I mention closed cell, because I choose products that don't absorb water. Oh, like water ever gets in our Healeys, right? The product goes under the name of Low-E. You can do a search on the www.
Photo 1. Pegasus product
Photo 2. Pegasus on bottom of the transmission tunnel
Photo 3. Low-E on the top of the transmission tunnel
As always, clean the surfaces well, before adhering any product. And look both ways before crossing the street and wash your hands before dinner.
Drive it like you stole it!
Roger
