Recently I had a problem with the transmission in my BN2 not shifting into reverse. The selector rod was locked tight.
After some research and removal of the side cover it looks like the problem is associated with the spring/ball bearing detents.
I did get the reverse selector rod to move after some fiddling, but I would like a more robust solution.
Does anyone have a diagram showing exactly how the lockout function of these detents works?
I would like to understand it before assuming it's fixed.
Thanks,
Bob
Thanks,
Bob
