How to check the transmission fluid level on a 1961 MG Midget, 1275 cc? I have put the recommended amount of fluid in but i want to make sure it is enough and my calculations were correct. My thoughts--take the rubber off the side of the crankcase and remove the filler nut. If when I can put my finder in the hole and feel fluid no more than 1/8" inch down, then there is the correct amount of fluid. Yes,/no?
Is there a replacement plug/nut for the original one that is easier to take off and put on?
tks.
tks.
