For Sale 72 TR6 clutch and transmission
TR6Canuck
I decided to replace my 72 TR6 4-speed transmission with the Miata 5-speed.
The TR6 clutch and transmission worked flawlessly. No mechanical issues with it, I just travel longer distances in my car and needed the five speed for highway use.
Located in Collingwood Ontario, can be brought to Toronto. Please reach out with offers.
Sonshine
Curious as to what you would like for the package …?.
AHOTTR6
. 0p I decided to replace my 72 TR6 4-speed transmission with the Miata 5-speed.
The TR6 clutch and transmission worked flawlessly. No mechanical issues with it, I just travel longer m9 distances in my car and needed the five speed for highway use.
TR6Canuck
TR6Canuck
Abs
How are you liking the Miata 5-speed? Just curious cause I was think about doing that to my TR3.
Thanks,
Joel
Very pleased with it. It allows me to cruise down the highway at 105 km an hour, at 2200 RPM. Very smooth shifting. Three things to be aware of: 1/the clutch pedal is a bit heavy to push down on, can be a bit tiring if you are on a long trip with lots of shifts. 2/ be aware that your speedometer will be out of calibration. On my car it actually works out that I just double the number that the needle is pointing to and that is my speed. 3/ the stick shift is longer than the original TR6, so the knob positions may or may not be comfortable for you. It wouldn't be difficult to shorten it if needed. None of these are deal breakers by any sense, extremely pleased with the decision.
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
Paulus TR6 TR6 Transmission noise when clutch engaged. Triumph 7
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
B TR6 TR6 1976 Clutch Choice Question Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
B TR6 TR6 clutch pedal height Triumph 2
Scot1966 TR6 TR6 Clutch Triumph 5
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
G TR6 TR6 Clutch Problem Triumph 22
D TR6 New poster, TR6 clutch problem Triumph 10
T TR6 tr6 clutch travel saga Triumph 1
K TR6 TR6 Trans in a TR3...What about clutch? Triumph 1
F TR6 triumph tr6 clutch problem Triumph 14
V TR6 TR6 Clutch Master Triumph 5
hondo402000 TR6 TR6 Clutch question Triumph 5
T TR6 TR6 clutch bleeding woes Triumph 28
hondo402000 TR6 New TR6 Clutch shaft, fork and beefy pin Triumph 3
hondo402000 TR6 TR6 Clutch cross shaft Triumph 9
T TR6 Borg & Beck or LUK clutch kit for the '74 TR6 Triumph 38
S TR6 CLUTCH ???????? TR6 Triumph 4
bigbadbluetr6 TR6 TR6 Clutch Hydaulics Triumph 12
wangdango TR6 '76 TR6 frozen clutch? Triumph 10
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
JKent TR6 TR6 clutch problems Triumph 16
SherpaPilot TR6 TR6 Clutch Question Triumph 3
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
mrv8q TR6 TR6 clutch line Q Triumph 26
bluemiata90 TR6 TR6 ADJUSTABLE CLUTCH ROD??? Triumph 17
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
K TR6 Could 70-76 TR6 Clutch master and slave ..... Triumph 1
T TR6 Replacing TR6 clutch and master cylinders Triumph 2
electric TR6 clutch whistle noise - 74 tr6 Triumph 9
F Brake and clutch fluid 73 TR6 Spridgets 9
F TR6 TR6 clutch noise Triumph 15
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
Brosky TR6 TSI Schumacher 3 piece TR6 clutch Triumph 0
Brosky TR6 TR6 V-8 Automatic, with optional clutch pedal Triumph 9
