TR6 72 TR6 clutch high engagement point
bfitz
Member
Trying to help a friend out. He had someone install a new clutch master and slave in his TR6. Engagement point has gone from normal to about 1/2" before top of pedal travel. Any ideas? This is a new one on me.
We're going to check the easy stuff like the slave cylinder mounting and fluid level, but was wondering if anyone's seen this before.
Thanks
rjc157
Moss sells an adjustable rod for about 35.00 it should help.Maybe with all new parts he has nothing to compare it too unless you have a tr6.
bfitz
bfitz
Member
Unfortunately, I've got a Jensen Healey. It has a cable clutch. Is there supposed to be any play in the clutch rod? His is under compression even when released. My car has .060 slack when released[yes, I set it with a feeler gauge] It's been a long time since I fought with a hydraulic clutch.
Air in the system would lower the engagement, right?
Gliderman8
Is there a slave return spring?
CJD
I was going to suggest you check the adjustment, to ensure the release bearing is not riding on the clutch diaphragm full time. Elliot's spring idea would cause that too.
But, if you are adjusted at the .06" play, then the release bearing should be disengaging and you should be good. The disc you used has a large affect on the release point. Many discs have a "springiness" to the faces to slow the engagement. If you have a disc with no spring, then the engagement point will be much higher. I have a newer model Vette with a hydraulic clutch, and it disengages within the first inch of travel. My TR2 waits until about an inch from the floor. It really freaks me out changing from one to the other, but both are working properly!
bfitz
bfitz
Member
You read that wrong, I adjusted the clutch on my Jensen to .060".
There is no adjustment on this TR and the clutch rod is under constant compression. No movement at all.
I'm starting to think there's a problem either in the master or the slave
Gliderman8
I believe that pic show the mounting to be incorrect... the mounting plate goes on the other side of the bell housing (I think). I only posted that pic to show the spring return. I have a hydraulic clutch in mine and it's been a while since I removed the slave but I do think the mounting plate needs to be moved. Hopefully others will chime in on the position of the mounting plate.
Gliderman8
Like this...
CJD
Then it needs to be adjusted properly. If there is zip clearance, then the release bearing is spinning at all times, and that explains the high engagement point. Without a return spring the slave cylinder may not return to it's compressed position.
In short, the adjustment is off.
CJD
Well, disregard! I just studied up on the TR6 manual. There is no adjustment at all, unlike the pics shown above. The TR6 is designed for the bearing to ride on the clutch.
There is nothing wrong with the clutch engaging with a high pedal, so long as it IS fully engaging. It sounds like your friend was accustomed to operating a worn out clutch...and how did the Jenson get in the conversation?!?
poolboy
This is a TR6 slave cylinder, properly mounted, no washers used as spacers, no external spring and no adjustable push rod.
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
B TR6 TR6 1976 Clutch Choice Question Triumph 3
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
M TR6 Which clutch master cylinder for a 71 TR6? Triumph 5
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
B TR6 TR6 clutch pedal height Triumph 2
Scot1966 TR6 TR6 Clutch Triumph 5
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
G TR6 TR6 Clutch Problem Triumph 22
D TR6 New poster, TR6 clutch problem Triumph 10
T TR6 tr6 clutch travel saga Triumph 1
K TR6 TR6 Trans in a TR3...What about clutch? Triumph 1
F TR6 triumph tr6 clutch problem Triumph 14
V TR6 TR6 Clutch Master Triumph 5
hondo402000 TR6 TR6 Clutch question Triumph 5
T TR6 TR6 clutch bleeding woes Triumph 28
hondo402000 TR6 New TR6 Clutch shaft, fork and beefy pin Triumph 3
hondo402000 TR6 TR6 Clutch cross shaft Triumph 9
T TR6 Borg & Beck or LUK clutch kit for the '74 TR6 Triumph 38
S TR6 CLUTCH ???????? TR6 Triumph 4
bigbadbluetr6 TR6 TR6 Clutch Hydaulics Triumph 12
wangdango TR6 '76 TR6 frozen clutch? Triumph 10
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
JKent TR6 TR6 clutch problems Triumph 16
SherpaPilot TR6 TR6 Clutch Question Triumph 3
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
mrv8q TR6 TR6 clutch line Q Triumph 26
bluemiata90 TR6 TR6 ADJUSTABLE CLUTCH ROD??? Triumph 17
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
K TR6 Could 70-76 TR6 Clutch master and slave ..... Triumph 1
T TR6 Replacing TR6 clutch and master cylinders Triumph 2
electric TR6 clutch whistle noise - 74 tr6 Triumph 9
F Brake and clutch fluid 73 TR6 Spridgets 9
F TR6 TR6 clutch noise Triumph 15
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
Brosky TR6 TSI Schumacher 3 piece TR6 clutch Triumph 0
Brosky TR6 TR6 V-8 Automatic, with optional clutch pedal Triumph 9
hondo402000 TR6 clutch for TR6 Triumph 10
