TR6 1974 TR6 clutch adjustment
RynoBoy74tr6
Hi folks! Hope everyone has had a great summer with their vehicles.
Quick question. My clutch/plate was replaced(previous owner) 10 years ago (12000 miles).
When the clutch pedal is fully depressed, the gear is still slightly engaged.
Is there a clutch adjustment anywhere to be made?
The manual doesn't say, or I'm looking in the wrong place!
Thanks!
stan
TR3driver
Great Pumpkin - R.I.P
Unfortunately, no direct adjustments. It is supposed to be self-adjusting, every time you release the pedal, the spring inside the slave should push the piston out until the TOB contacts the pressure plate.
But there are some common ways to 'improve' it. First thing to check is the condition of the joint between the clutch pedal and the MC pushrod. It's quite common for it to wear and so lose motion. The pin can be easily replaced, but fixing the holes in the pedal & pushrod is a bit harder. One solution might be to ream the holes oversize and use a metric bolt in place of the pin.
Another improvement is to replace the plastic line (which balloons somewhat under pressure) with Teflon. I know TSi makes these up, probably others do as well.
https://www.tsimportedautomotive.com/
Yet another, more extreme approach is the replace the MC with the larger bore unit used on very early TR6. This gives a firmer pedal, but more travel at the slave.
John_Mc
Another spot to check for play is in the bushing between the clutch pedal and the pedal shaft (No. 47 in <span style="color: #FF0000"> THIS diagram </span> ). I replaced my plastic hydraulic line with the s.s. line and that helped a bit, but I discovered my pedal shaft bushing was missing entirely, and when I replaced that, the problems cleared up. Huge difference.
John_Mc
I'm going to guess "No", but I imagine it is a problem nonetheless!
John_Mc
No. 42 in that diagram is the hose Randall mentioned replacing. Moss has original style, aftermarket, and stainless steel. I used the stainless steel. I don't know how that compares to teflon.
martx-5
Another possibility is the dreaded clutch fork pin. If you have acceptable throw on the slave cylinder, then the fork pin might have sheared. They don't shear cleanly, so you always seem to get some movement from the throwout bearing, but not enough to fully disengage the clutch.
TR3driver
Same thing. The stainless is just an outer braid to protect the inner Teflon tube from abrasion and whatnot.
I thought about mentioning the dreaded broken taper pin, but it's worth checking the easy stuff first. Apparently, worn out thrust washers can cause the same problem.
TR3driver
RynoBoy74tr6 said:
Hmmmm....If the tranny fluid was low,REALLY low, would that be a cause of my symptoms?..
That would depend on what the exact symptoms are. It couldn't cause the clutch to drag with the pedal fully depressed, but might make it hard to shift.
A clear test for clutch drag is to hold the pedal depressed with the car stopped and engine idling. Shift into 2nd, back to neutral, wait a beat, then try to get into reverse. If the gears grind, then the clutch (or pilot bearing) is definitely dragging.
RynoBoy74tr6
RynoBoy74tr6
I went and checked the pedal for play...It has 1 1/4" of play before encountering any resistance...Does this help indicate anything? That's with the engine off, parked in 1st gear.
MDCanaday
There is an adjustable clutch rod that helps the tr6,but not if the release fork pin is shot....I bet you have a winter project to get physicked up for. Dont forget to re-bush the cross shaft too !!
MD(mad dog)
TR3driver
Yup, pretty clearly indicates a lot of lost motion in the linkage. You could try checking under the car to see if the slave pushrod is loose, but I'll bet it's mostly at the pedal/MC pivot.
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
A For Sale 1974 TR6 Triumph Classifieds 1
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
H TR6 1974 tr6 allison xr700 Triumph 12
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
G TR6 1974 TR6 distributor advance spring specs Triumph 6
2 TR6 Price Reduces on 1974 TR6 W/Ovewrdrive. excellent Triumph 0
TR6BobNF TR6 1974 O/D TR6 For Sale in Newfoundland Triumph 1
I TR6 1974 tr6 Triumph 2
W TR6 Tr6 1974 Distributor Triumph 7
T TR6 1974 TR6 coil question Triumph 3
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
2wrench TR6 Which water pump for my April 1974 TR6 Triumph 3
2wrench TR6 1974 TR6 Engine Rebuild and/or Repair Triumph 26
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
T TR6 Swapping 1974 TR6 fenders on to my 71 TR6? Triumph 5
D Trying to get back working on the 1974 Midget Spridgets 11
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
VeeCee MGB 1974 MGB Roof Installation MG 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
J 1974 Jensen Other British Cars 22
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
P MGB 1974 MGB front spring length. MG 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
A MGB MGB 1974 windscreen centre rod replacement MG 5
R SOLD!! 1974 Jensen Healey Other British Classifieds 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
krswen For Sale 1974 Panther J72 Other British Classifieds 4
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
A 1974 2500M Spring Rates TVR 6
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
B 1974 Midget Spridgets 6
jmayzer For Sale 1974 MG Midget Mk III [Maryland, USA] Spridgets Classified 1
J MGB 1974 1/2 MGB gasoline type MG 5
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
wkilleffer MGB 1974 MGB convertible top anchor bar size MG 4
