TR6 1974 TR6 distributor advance spring specs
gtemkin
My distributor was taken apart and the springs were mixed in with springs from other Lucas distributors. Would anyone know the wire diameter, outside diameter, number of turns, and overall length information so I can find the ones that were there originally. Rough measurements might be fine cause there's only 10 springs to sort from.
Thanks,
Gregg
hondo402000
Greg you might be better off sending the unit off to Advanced distributors, he rebuilt mine and it works great, before the weights were frozen. he also puts a new bushing in and checks the whole thing, and will recurve it
if you didnt take the springs off how will you even begin to get the right ones back on
Hondo
G
gtemkin
By the way, I'm the one who mixed the springs together. My bad.
Spring forces are governed primarily by material properties (alloy and temper) and winding dimensions. If we ignore the material aspects, for the purposes of sorting, then the winding dimension specs should be fine to get me in the ballpark. I know there are plenty of opportunities for tweaking things, but I'm just looking for the basic spring setup, so I can hav a starting point.
Gregg
Brosky
You will need someone with a distributor taken apart. Otherwise the stretched spring measurement would be meaningless.
Geo Hahn
I would expect one spring (thin wire) to be very close to its relaxed length with the weights at rest and the other spring (thick wire) to be slack (i.e at its relaxed length) with the weights at rest. So measurements & descriptions in situ should get you pretty close.
In fact, a good digital photo may be enough to go on.
Frozen weights are easily fixed... once the distributor is out there is really only one screw (under the rotor) holding things together.
I have never understood how someone can properly recurve a distributor without matching the curve to the engine (other than just installing the stock springs).
hondo402000
Geo, you are correct, there is a lot more information needed to recurve a distributor properly, I didnt see the need to list all that informtion, if Gregg was planning to send it off to Advanced Dist, or someone else they would have asked him for more details
G
gtemkin
I have a number of reasons why I don't want to send my distro away to be setup right now. Just want a close to stock setup to get the car running.
I like the approach mentioned of judging the primary spring by a slight tension at rest and ensuring the secondary spring is selected to allow delay before it's put under tension.
Since the spring mixup was between distros for 4 cylinder BMC A series cars and the TR-6 distro I'm hoping they designed the at rest length entirely differently and the resorting will then be simple.
Thanks, for the great suggestions.
Gregg
W TR6 Tr6 1974 Distributor Triumph 7
A For Sale 1974 TR6 Triumph Classifieds 1
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
H TR6 1974 tr6 allison xr700 Triumph 12
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
2 TR6 Price Reduces on 1974 TR6 W/Ovewrdrive. excellent Triumph 0
TR6BobNF TR6 1974 O/D TR6 For Sale in Newfoundland Triumph 1
I TR6 1974 tr6 Triumph 2
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
T TR6 1974 TR6 coil question Triumph 3
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
2wrench TR6 Which water pump for my April 1974 TR6 Triumph 3
2wrench TR6 1974 TR6 Engine Rebuild and/or Repair Triumph 26
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
T TR6 Swapping 1974 TR6 fenders on to my 71 TR6? Triumph 5
D Trying to get back working on the 1974 Midget Spridgets 11
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
VeeCee MGB 1974 MGB Roof Installation MG 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
J 1974 Jensen Other British Cars 22
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
P MGB 1974 MGB front spring length. MG 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
A MGB MGB 1974 windscreen centre rod replacement MG 5
R SOLD!! 1974 Jensen Healey Other British Classifieds 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
krswen For Sale 1974 Panther J72 Other British Classifieds 4
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
A 1974 2500M Spring Rates TVR 6
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
B 1974 Midget Spridgets 6
jmayzer For Sale 1974 MG Midget Mk III [Maryland, USA] Spridgets Classified 1
J MGB 1974 1/2 MGB gasoline type MG 5
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
wkilleffer MGB 1974 MGB convertible top anchor bar size MG 4
