As a new member I don't know if this is the proper place to seek advice but, here goes: I have a 1974 TR6 that I've had and worked on for 40+ years. I thought I must have encountered most every glitch at one time or another - not so. The rear brake cyls. apparently leaked out over winter storage so I replaced them and then tried to bleed them. The fronts work great but the left rear has only the tiniest bit of pressure and the right has none. The master cyl. is OK and the PDWA has fluid in and fluid out to the rear unions. Does anyone have a suggestion?
