1974 Jensen INterceptor electrical help needed
mvpvail
I am new to british cars and this website.......I am in Atlanta Georgia USA, and recently purchased a beautiful 2 owner Interceptor convertible, original paint 20,000 miles from Calif from a long time family friend.
I have rebuilt a few things like the steering rack and the carb and tuned it up.
Electrical issues abound though, like none of the 4 power windows work, the front side marker lights do not work, the 3 interior courtesy light do not come on, the flexible under bonnet light does not work, the horns do not work, the radio aerial does not go up or down, but radio comes on, the ac compressor does not cycle and the front passenger side headlight and brights do not work, left sides does come on. I have checked many fuses, changed many bulbs and no good results............I have a wiring diagram and chassis manual, but I'm not really an electrical genius. All thoughts are appreciated. Mark
pdplot
If you don't have a continuity tester and a test light, and perhaps a multimeter, or don't know how to use them, to save time, aggravation and maybe a fire or two, take the car to a skilled and experienced auto technician and pay him to trace out all circuits.
JPSmit
Mark, welcome!!! Glad you are here and I am only a little envious of your car - and we very much need pictures!
I can't tell you much about the marque specifically but, can tell you a few things generally.
1. If you don't have them, go get a continuity tester and a meter from Harbor Freight (or elsewhere cheap)
1. 90 plus percent of the time electrical problems are issues with grounds. Ground wires are black - find every end you can and clean and re-attach.
2. Check your fuse box - confirm that the fuses work with the continuity tester NOT sight as often the wires break under the cap. While you are at it, check the metal clips the fuses rest in, the rivets loosen over time.
3. Wiring does not require a genius - just the ability to trace wires and the time to understand colours - Take your manual to Staples and get the wiring diagram blown up as big as you can on the photocopier, buy some markers and start colouring. (seriously) British wiring is standard - so, for instance, almost all your niggles will be (likely) related to green wires - or green+ something else (12 V - ignition on)
4. Your horn should be a purple wire - but, there especially, most likely a ground - the ground BTW will be at the horn not the horn push.
5. One thing (circuit) at a time - your manual should tell you what circuits feed what ancillaries - so, you should be able to narrow it down.
6. If I can do it, anyone can - go slow and methodically and you should be fine.
Keep us posted and feel free to ask specific questions.
good luck!
Bayless
Certainly best to do the diagnosis yourself. A wiring diagram and test meter and time is all that's required. Sending it to a professional to track down wiring problems can get really expensive as it can be really time consuming. Going shop rates are $100/hour or more these days. Oh, forgot to add, I'm also envious of your car.
M
mvpvail
Thanks for the comments..........we shall see tomorrow as I am taking the car to a good ol boy in Cumming, GA for him to try some of these things. I did get the passenger side headlights to work though............not really sure what I did but I took the headlights out and started cleaning and voila!!!!!!!!!!!!!!
NutmegCT
Mark - that's the first thing to do with non-working lights. Test the bulb to see if it's burned out, then clean all the contacts in the socket (and check for blown fuse and loose wires).
And there are several good ways of cleaning those contacts.
One step forward!
Tom M.
number6
I second what JP said. I have had tons of bad ground issues with my Spitfire Sabrina. Makes me believe the car spent a lot of time at the ocean.
Had similar issues with marker lights and turn signals. Emergency flashers were always a problem until I took emery cloth to the fuse box terminals.
I also am envious of your car. Want to trade it for a Horch? Just kidding. Good luck.
M
mvpvail
Ok so I drove the car for the first time ever after much detailing and rack and carb rebuild ,to the guy who is working on the few electrical issues. Fun car and fairly fast.
M
mvpvail
I also had replaced the front end bushings and all rubber components and the rear shackle bushings..................Really alot of fun to drive even with just 8.2/1 compression........I thought i'd be a dog..........
Are the front red side marker lights supposed to be on when the headlights are on? They are not now but maybe after the local guy tries.........we shall see.
J 1974 Jensen Other British Cars 22
R SOLD!! 1974 Jensen Healey Other British Classifieds 0
T 1974 jensen healey Other British Cars 17
D Found a 1974 Jensen Healey Spotted 3
D Trying to get back working on the 1974 Midget Spridgets 11
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
VeeCee MGB 1974 MGB Roof Installation MG 0
A For Sale 1974 TR6 Triumph Classifieds 1
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
P MGB 1974 MGB front spring length. MG 0
H TR6 1974 tr6 allison xr700 Triumph 12
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
A MGB MGB 1974 windscreen centre rod replacement MG 5
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
krswen For Sale 1974 Panther J72 Other British Classifieds 4
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
A 1974 2500M Spring Rates TVR 6
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
B 1974 Midget Spridgets 6
jmayzer For Sale 1974 MG Midget Mk III [Maryland, USA] Spridgets Classified 1
J MGB 1974 1/2 MGB gasoline type MG 5
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
wkilleffer MGB 1974 MGB convertible top anchor bar size MG 4
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
F MGB Correct steering wheel - 1974 MG 2
AngliaGT 1974 Midget - It's ALIVE!!! Spridgets 7
AngliaGT Early [11/73] 1974 Radiator Removal - Spridgets 4
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
S TR6 1974 TR-6 project....I'm holding my breath and praying Triumph 13
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
wkilleffer T-Series Clutch pipe installation- 1974 MGB MG 2
aeronca65t Summit Point-1974 Racing 1
G TR6 1974 TR6 distributor advance spring specs Triumph 6
jsfbond 1974??? Triumph 3
