TR6 new TR6 transmission popping out of gear
hondo402000
after having my transmission rebuilt and getting back on the road, its jumping out of gear in first and 3rd, I contacted the transmission rebuilder and he said that all the specs are correct for the syncros, springs and gear clearances, he said he must have not got the spring and balls that make the selector switch at the right tension since he used a digital fish scale, wouldnt it be better if you used the old fashion spring gauge, any way he says to pull the cover off and adjust the spring tension and the would take care of it
any suggestions if all else is correct are the detent balls the issue
Hondo
sail
Sounds like thats it. Use a scale but you can also feel what is right.
Brosky
Just make sure that you are not hitting against the inside of the console since it is happening in 1st & 3rd only. Under full torque, or deceleration, the gearbox may move slightly on the mounts with torque twist and be forced out of gear.
TR3driver
Great Pumpkin - R.I.P
Digital fish scale should work fine, if you work slowly and give it time to update. That's what I use.
Were any of the gears replaced? There is a subtle difference between gear sets that sometimes gets overlooked; and a mismatch can cause jumping out of gear.
https://trf.zeni.net/TR6bluebook/index.php?page=85
19_again
Hopefully Brosky is right. That is exactly what happened tome with my MGB, the trim ring on the shift boot was reversed, (by you know who) and while it seemed like I had the gears engaged, they were only partially engaged, Cheap quick fix, go there first. The 1st and 3rd hints point right to that solution.
hondo402000
hondo402000
as far as gears, I know the layshaft was replaced, and reverse, I would have to check my invoice to see if anything else was replaced
Hondo
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
C TR6 TR6 Transmission Triumph 5
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
hondo402000 TR6 New Transmission parts for TR6 Triumph 5
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
hondo402000 TR6 Transmission Leak TR6 Triumph 28
hondo402000 TR6 Transmission Seals, TR6, where to get them Triumph 2
hondo402000 TR6 Leaking Transmission solved TR6 Triumph 5
hondo402000 TR6 TR6 Transmission leak Triumph 5
bobh TR6 New TR6 Transmission Conversion Triumph 3
V TR6 Need a Transmission cooler for your TR6? Triumph 4
cmacmillan TR6 Cleaning the transmission on a TR6? Triumph 18
SCguy TR6 Transmission Swap in my TR6 Triumph 14
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
Paulus TR6 TR6 Speedometer problem in transmission housing Triumph 5
G TR6 [TR6] removal of front transmission seal Triumph 5
Paulus TR6 TR6 Transmission noise when clutch engaged. Triumph 7
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
Slider748 TR6 Re-installing TR6 transmission Triumph 14
Slider748 TR6 TR6 transmission removal problem Triumph 12
71tr TR6 Transmission Rebuild [TR6] Triumph 2
A TR6 TR6 Transmission Identification ??? Triumph 3
A TR6 TR6 Transmission Rebuild Woes Triumph 2
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
