TR4/4A Covers at side of H frame over the trans tunnel...ideas please.
malbaby
Looking for ideas on what to do about side covers for the H frame on the trans tunnel, as I intend to fit a radio.
Have made up a template in cardboard as one idea, intending to use some alloy sheet cut to size and painted the same colour as the H frame.
charleyf
Malbaby,
So you want your car to be "refined and pretty"?
The TR6 uses covers like what you are thinking of. Those are made out of cardboard with a vinyl covering. Material similar to trunk panel that covers the fuel tank.
Charley
Foura
Malbaby, you are looking for console pads or knee pads. I thought that mine came from Moss via The Healey Factory in Melbourne, but I cannot find them in either the Moss or Rimmer catalogues. They were vinyl over foam over MDF board. After a couple of removals and replacements, they broke in the middle where the board was thinnest. I removed the vinyl and foam and remade the panels in ply. Some of them came with speaker holes, but I think that ply or alloy is too thin to give a firm mount for a reasonable speaker and the sound is going into the footwell. I have MX5 seats with the speakers in the headrests.
You have to allow clearance at the bottom of the panel to allow the heat to get to your feet from your heater.
M
malbaby
Thanks guys....I had not thought of making side covers extending to the floor....I will make up some templates to see how it looks to me.
TuffTR250
Normally the kidney pads that TRF sells are for TR6's because the H-frame on a TR6 has a small ledge built into it toward the top of the legs to support the front of the kidney pad. Since I wanted kidney pads on my TR250, I bought a TR6 H-frame and am just holding onto my TR250 H-Frame in case I want to go back to original. The ledge is not built into the metal of the H-frame but is formed out of the "foam" under the vinyl cover.
Regards,
Bob
Foura
They don't go to the floor. They have a metal bracket that fits over the lip on the back of the H bracket and they go
all the way to the firewall. You have to make your own bracket to fix them to the firewall. You can use the fixing bolts for the overdrive relay on the left hand side and make you own on the right hand side. The narrow centre section lets the hot (??!!) air from the heater go down in the approximate direction of your feet.
Their only real functions are to hide the mess of English wiring, the side of the radio and to give a softer surface for your leg to rest against. All important issues.:encouragement:
Geo Hahn
A Velcro seat belt wrap (sold at most auto parts departments) can be used on the dash support to provide some padding for the driver's right knee:
M
malbaby
Thanks again,
I did not know that there were 2 different types of H frames.
I was originally thinking of just hiding the radio and wiring, but now side pads for legs is a worthwhile idea.
charleyf
The TR4A H frame or dash support is the one pictured in the earlier photos while the TR4 is the one in the later photo. I doubt they are interchangeable without a lot of work.
Charley
bighealeysource oil leaking from engine side covers Austin Healey 25
SpannerMan TR6 TR6 - seat covers interchange side-to-side? Triumph 2
Nunyas Late model 'B engine block side covers.. MG 6
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
D New seat covers Spridgets 11
shadowfever Moss Motors MG Midget seat covers Spridgets 6
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
M Ray Juncal Valve Covers Austin Healey 5
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
R bugeye slip covers Spridgets 1
F Seat Covers Austin Healey 1
P For Sale mgb seat covers MG Classifieds 0
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
HealeyPassion Survey of Ruddspeed valve covers Austin Healey 37
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
6 Seat Covers Spridgets 9
charleyf For Sale TR4 seat covers -new Triumph Classifieds 0
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
TulsaFred New Bugeye Seat Covers from AH Spares don't seem to fit properly Spridgets 10
M General MG Sheepskin seat covers? MG 4
M General TR Sheepskin seat covers? Triumph 0
S TR2/3/3A Steering wheel covers Triumph 9
B TR2/3/3A anyone else had trouble with TRFs wheel bearing dust covers? Triumph 5
S TR2/3/3A new seat covers on original seat frames Triumph 1
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
J TR6 TR6 Seat Covers Triumph 0
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
A car covers Austin Healey 6
S TR2/3/3A rocker covers again Triumph 13
R Early BN4 Seat Covers Austin Healey 10
J TR2/3/3A Interior rear wheel arch covers question. Triumph 2
D TR4/4A TR-250 seat covers on TR-4 seats Triumph 3
krswen Question about XJ6 cam covers Jaguar 6
aeronca65t Pittsburgh Vintage Grand Prix-starts on July 11 [and covers two weekends] Racing 0
MikeAH100M No Valve Cover Breather - Alloy Valve Covers Austin Healey 5
G TR4/4A Emergency brake dust covers Triumph 4
B MGB watford seat covers $90.00???? MG 3
Kleykamp TR2/3/3A Amco seat covers Triumph 0
S Were Valve Covers Ever Painted Blue? Austin Healey 8
I General TR Steering wheel covers Triumph 3
Bruce Bowker Series 3 seat covers Jaguar 3
glemon Ever seen these wheel covers? Spridgets 5
Got_All_4 Wedge Tr7 plaid seat covers Triumph 15
Kleykamp Hole pattern on spare tire lock covers??? Triumph 5
J TR2/3/3A Tr3a Fitting Kruso Seat Covers Triumph 19
jhorton3 Replacecment Miata Seat Covers Spridgets 12
rjc157 VB seat covers Austin Healey 4
