TR2/3/3A Hole on top of my tranny tunnel
Tinkerman
On my 1960 TR3A tranny tunnel there is a 1/2 inch(approx) hole on the top, on the passenger side of the tunnel and about 2.5" from the front lip. Is that for the battery drain tube?
Thanks, Tinkerman
Jerry
Battery and the air conditioning vent hose. put a T in the line and dump both into that hole.
Jerry
Tinkerman
Tinkerman
My thanks for the info and the tip on the "T"!
Got to be the fastest answer on the forum. I know it's the fastest that I have ever gotten! Gotta love the BCF!!!!!!!!!!!!!!!!
Dick
mgedit
That's very true Dick. The odd time I know the answer to a question I usually find 3-4 people have already answered before I even see the question. Great resource for us all.
Cheers, Mike
doc50
Wait...air conditioning? I have never heard of AC on these cars!!
Is there an optional AC unit????
Thom
TC34909L(O)
mgedit
Only if you consider the air from the front vent to be air conditioned :smile:
Cheers, Mike
Tinkerman
Tinkerman
It has been suggested to me that hole is for the overdrive wire feed through. Can that be possible? It would make sense because of where the wires have to go to hit the switches on the top of the gear box cover.
Further comments solicited.
Thanks, Dick
TR3driver
Great Pumpkin - R.I.P
Check out Fig 2 on page N3 of the workshop manual. It pretty clearly shows the battery box drain going to the hole on top.
I can't find the reference at the moment, but I'm fairly certain that the factory routed the OD wires on the TR3 through the hole located low on the LH side of the tunnel. I don't like that location, so mine are routed out through one of the holes in the vertical part of the firewall, and go back to the switches & solenoid. That way I don't have to mess with the wires when R&R the tunnel. (Got the idea from Triumph, that's the original routing on Stags.)
Tinkerman
Tinkerman
Fairly conclusive, Eh Randall!
Forget to look in the factory manual to answer questions like that! Need to rummage around in there more often, I guess heh.
Appreciate it, Dick
W Top or Tonneau cover hole? MG 17
SpeedyG TR4/4A Hole in my firewall Triumph 12
apbos The next rabbit hole. Help ID the chassis. Racing 27
M 1500 Midget water pump weep hole Spridgets 2
B How big is the floor pan drain hole? Spridgets 0
B tachometer cable has a hole in it Restoration & Tools 7
JFS Wedge Stripped gearbox filler hole thread Triumph 3
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
Walter74 Unknown Hole Purpose Austin Healey 2
T TR2/3/3A Clutch Pushrod hole location Triumph 4
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
D TR2/3/3A extra hole in my water pump? Triumph 3
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
L TR2/3/3A Purpose of the hole in a bracket Triumph 8
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
S TR2/3/3A clutch pedal connection hole Triumph 9
P TR6 Rocker panel hole Triumph 16
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Strange hole! Triumph 5
J TR2/3/3A Hole in Rear Hub Triumph 7
Jim_Stevens TR2/3/3A Antenna hole? Triumph 11
ckeithjordan TR2/3/3A Trim Hole Size Triumph 3
R TR6 Trunion Hole Triumph 2
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
R TR2/3/3A Timing hole alignment Triumph 1
D TR4/4A water pump mystery hole Triumph 6
T TR6 What's this hole for? Triumph 5
wingsandwheels MGB new project...need like a hole in the head MG 8
S TR2/3/3A gas tank hole body work Triumph 7
T Grommet - sling hole in floor - XMSC108 Spridgets 3
R Plug bell housing/clutch housing hole? Austin Healey 10
Jim_Gruber What is this for, 3 holes + 1 Large hole on rear License Plate Indent on BE Spridgets 17
R water pump small hole does line up Austin Healey 7
Griz What is this hole for? Austin Healey 10
L What is this mounting hole for ? Spridgets 7
T TR2/3/3A Antenna Hole Blanking Plug/Fender Mirror Placement Triumph 6
cmacmillan TR6 75 TR6 Weep hole weeping.... Triumph 2
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
6TTR3A TR2/3/3A Complete firewall hole illustration Triumph 3
K TR2/3/3A Clutch Operating Shaft with bolt hole in wrong location? Triumph 3
K TR2/3/3A Ovalled bush hole in lower A arm front suspension. Triumph 1
S hole for speedo cable Austin Healey 1
S hole for speedo cable Austin Healey 6
AHS TR2/3/3A Dashboard hole identification Triumph 8
