TR2/3/3A clutch pedal connection hole
sp53
This clutch pedal connection hole is egged shaped and I am looking for suggestion on how to fill the hole some, and re-drill it. I just have a Sears’s middle of the road 110v mig welder, so can I fill this hole with it somehow. I guess turn the machine up and maybe I set the feeder like 2 and just give the weld hole short blasts and just keep caking the hole full of wire. Should I heat this piece up first or maybe have it filled with a stronger welder?
Geo Hahn
Seems to me (who has never done this) that a bushing welded or brazed into the (possibly enlarged) hole would give you the precise hole you need with less welding.
TomMull
I try to find or make a bushing for it. Tom
TR3driver
Great Pumpkin - R.I.P
FWIW, any hobby store should be able to sell you thin wall brass tubing. Ream the hole more or less round, force the tubing into it, trim off the excess. No heat required.
CJD
The bushing is an option, but with the arm only 3/16" wide there is not much bearing area for a bronze bush. The large sleeved center pivot would take a bronze sleeve easier, as it has much more bearing surface.
All of my linkages were oval. I fixed them by welding the holes completely closed and then carefully grinding the surfaces flat. Then, very important, I heated the area where the hole will be re-drilled to red hot with a torch...then allowed it to slowly cool by gradually removing the flame. This step is important, as it anneals the area and prevents chipping your drill bit on accidentally hardened spots in the weld.
These are not the exact same, but post #16 in this thread shows a bit of how I did it:
https://www.britishcarforum.com/bcf/showthread.php?96267-Early-Lockheed-Master-Cylinders
M_Pied_Lourd
I added weld to mine and redrilled.
Cheers,
Tush
S
sp53
Hey John, Would you think I need to heat the metal before the weld because of the smaller welder, but it really is kinda strong? Plus would you suggest my highest temp setting 1 thru 4 and then short blasts with a MIG and just build things up.
steve
CJD
No need to pre-heat. The pedal is low carbon steel, so it will take the weld without any problems. Match your welder heat setting to the thickness of the work. In this case about 3/16" steel should be level 3...and possibly even level 4 would work. Of course you will have to turn up your feed to correspond with the higher temp. If the feed is too slow, it will act like the weld is "skipping", with pauses during the weld. Slow feed also causes the wire to get stuck frequently in the tip, so you have to stop and clear the tip frequently. Fast feed spatters a whole lot, tends to get the wire stuck in the work, and pushes the tip away. So turn the feed up about 50% from where you have been working, and then read it from there to see if you need to adjust a bit.
As you say, work in small lines, building with each subsequent line. For such a small hole it will be relatively short bursts...like 2-4 seconds each. After all the thin metal welding you have done, this thick metal welding is pretty easy in contrast!
charleyf
+1 with Tush. And I have a Miller 110 V. Welder. I have done two with good results. No preheating or post heating done. I wonder if John's setting instructions are't for the 220 welders. I probably used 6 or higher.
TR3driver
Bronze (as in sintered bronze aka Oilite) might be a problem. But I've used hard brass as I suggested, and it works fine. It basically forms a soft face to the steel lever (the strength is still in the steel) similar to a rod bearing.
Yeah, it might wear out in another 50-60 years, especially if you neglect to add the occasional drop of oil. Then if you are still around, you can tap out the old remains, and use up another 1/4 inch of tubing.
But I expect to be beyond caring by that point :smile:
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T Clutch Pedal Engagement Point Austin Healey 1
Jeepster Clutch Pedal Position Austin Healey 4
C BN1 Clutch Pedal Rattle Austin Healey 2
G TR6 Binding Clutch Pedal Triumph 5
D TR2/3/3A clutch/brake pedal question Triumph 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
P TR6 Clutch pedal click noise Triumph 2
P TR6 Clutch pedal noise Triumph 2
B TR2/3/3A Where on the clutch pedal? Triumph 4
tomshobby TR6 power assist for clutch pedal Triumph 12
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
B TR6 TR6 clutch pedal height Triumph 2
Lukens TR2/3/3A Occasional soft clutch pedal? Triumph 2
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
aeronca65t Clutch pedal problem- 1275 race car Spridgets 12
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
Patrick67BJ8 Clutch Pedal Won't Go All The Way To The Floor Austin Healey 20
K TR2/3/3A Replacing Clutch Pedal Triumph 8
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
B argh,,clutch pedal to floor Spridgets 6
Scotsman Adjusting clutch pedal travel Triumph 2
bighealeysource Feel vibration when depressing clutch pedal on BN2 Austin Healey 4
T TR2/3/3A TR3a Clutch Pedal Return Triumph 2
T TR4/4A Anyone have a spare TR4a clutch pedal? Triumph 3
aeronca65t Common problem-clutch pedal Spridgets 2
B Clutch pedal no fluid? 2 -3 years of sitting... Spridgets 30
W Clutch Pedal Feel Austin Healey 3
A T-Series Clutch pedal slow to rise MG 11
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
F RHD Clutch Pedal Jaguar 1
W Clutch Pedal Jaguar 8
CJD Brake/Clutch pedal adjustment Triumph 29
RJS TR4/4A TR4A Heavy Clutch Pedal Triumph 2
M Clutch pedal noise Triumph 16
pipercollins Part Wanted: Clutch Pedal Triumph 2
S Floppy clutch pedal Triumph 5
1 T-Series Clutch pedal travel and point of engagement MG 5
J Brake/clutch pedal frozen Triumph 18
dklawson Rhetorical Question/Comment - Use of Clutch Pedal? Triumph 29
M Bugeye clutch pedal sticking Spridgets 2
P weird thing with midget clutch pedal Spridgets 3
D clutch pedal Spridgets 4
DMShuman TR5/TR250 TR 250 issue with Clutch pedal Triumph 4
S BN1 clutch and brake pedal bracket Austin Healey 3
Lin clutch pedal Spridgets 2
tomshobby A way to lube the clutch pedal pivot. Triumph 1
Brosky TR6 TR6 V-8 Automatic, with optional clutch pedal Triumph 9
G TR6 Are you happy with your TR6 clutch pedal play? Triumph 28
