Brake/clutch pedal frozen
JonnyRotten
linkage moves to the brackets going through engine compartment.but the brackets are frozen.Is that the master cylinder that needs to be rebuilt.
NickMorgan
A little more information. What car is this? Do both pedals move together? How long since it was last used?
Unusual for both the brake and clutch master cylinders to be solid like that.
J
JonnyRotten
Its a 60 tr3a.It hasn't moved in 30 years,but its been garaged.both pedals frozen.They move independently.The brackets going through engine compartment are frozen solid.
ekamm
Johnny has just received his dads old tr3 and it's been sitting for a very long time. He just stared it first time yesterday.
M_Pied_Lourd
Probably the clutch and brake master cylinders on the bulkhead are rusted solid.
I am sure that you are investing in new hydraulics for the car anyway, so I would remove both cylinders and see if after the pedals will move when they are not hooked up.
I supposed the bushings could be rusted in the pedals themselves?
Cheers,
M. Pied Lourd
J
JonnyRotten
I have movement to the brackets.Can rusted solid master cylinders be rebuilt.Im redoing the whole system.the lines and calipers are easy,I figured Id start with the hard stuff.
NickMorgan
It is possible to hone them out and re-seal them if they are not too bad. But I would be inclined to fit new cylinders as they are not that expensive and you should then have a reliable system. If they have been sitting for 30 years the liklihood is that they will be beyond economic repair.
Hatman
I had Sierra resleeve my brake and clutch MCs last winter. They did a great job -- I did quite a bit of searching on the 'net and talking with folks on this board before I chose them. While you can buy replacement MCs for the same price, I was advised by quite a few knowledgeable folks that the resleeved original MCs are of much higher quality than the current replacements. Plus, the replacements available are not exact matches for your OEM MCs, so you have to do some fabricating to make them fit and you lose the original appearance, if that's a factor that's important to you.
Sierra is at: https://www.brakecylinder.com/
SkinnedKnuckles
:iagree:
I second the resleeve option for the brake & clutch masters. Slave/wheel cylinders can be replaced cheaply, and the calipers likely rebuidable youself.
TR3driver
Great Pumpkin - R.I.P
Your car won't have the twin cylinder MC, that was found only on TR2-early TR3 with Lockheed brakes (and front drums). Girling MCs (P/N GI64067854) are currently on sale @ TRF for $75 each. And while they are visibly different, fitting them is trivial. They come with the adapter for the outlet, so at most you just bend your existing lines slightly to match the outlet location.
PS, before deciding anything, I would disconnect the linkage at the MC pushrods (remove cotter pin then unscrew funny threaded clevis pin through hole in side) and re-evaluate the situation. I have seen TRs with both pedals rusted to the pivot rod. And your existing MCs may be repairable without sleeves. TS13571L is still wearing it's original cylinders (though I may try my hand at resleeving them someday).
Gordon_Dedrick
I believe Apple Hydralics is near you in Long Island. They do rebuilds I think along with White Post Resorations in Virginia. It might be worthwhile if you have the ORIGINALS resleeved.
Gordon
dklawson
So for re-sleeving there is Sierra, White Post, and Apple? Is there any consensus in the LBC world about which does a better job? I've heard that some of these vendors won't honor warranties if you use DOT-5 brake fluid. Is that true of all the re-sleeving firms?
M_Pied_Lourd
JR,
I just did this job last week and replaced the old mc's with new ones from TRF. Agreed, if you can rebuild/re-sleeve your originals these can be more dependable in the long run than the new repros.
Here are a few pics of the masters and reservoir on my 60 3A.
Cheers,
M. Pied Lourd
J
JonnyRotten
Thanks for the pics.my mistake.Its not the MCs.Its the linkage thats frozen.How do I get to the linkage that the clevis pin is attached to. .After getting under the car it appears to be IN the body.(sorry for the wrong info)
ekamm
The pedal setup is behind the firewall under the dash.
TR3driver
Now comes the fun part ! There is a series of bolts & studs that hold the pedal assembly to the body. 4 or 5 bolts from inside, plus 4 studs that stick up into the box that holds the MCs. Probably best to remove the box first, as things are likely to be rusty and need attention under there anyway.
Once all the nuts & bolts are out (plus the clevis pins of course), the pedals should pull away from the body, along with the brackets, pivots, etc. If they are reluctant, some taps with a brass hammer above the clevis pins should help.
TR3driver
Here's a shot from the factory SPC that might help too.
D TR2/3/3A clutch/brake pedal question Triumph 4
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
CJD Brake/Clutch pedal adjustment Triumph 29
S BN1 clutch and brake pedal bracket Austin Healey 3
LuckyLuke 100-4 brake / clutch pedal seals not available Austin Healey 3
B gas, Brake, Clutch Pedal covers? Spridgets 8
Lin Brake/Clutch Fluid Austin Healey 11
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
B Flushing brake/clutch Austin Healey 16
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
SD Bugeye Clutch and brake clevis and pins Spridgets 3
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
vette Brake/Clutch Reservoir Austin Healey 14
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Brake/Clutch Reservoir Seal Triumph 9
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
K TR2/3/3A Brake and clutch MC housing.... Triumph 2
petnatcar GAS, BRAKE and CLUTCH PEDALS for a BT7 Austin Healey 2
D Brake/clutch lines Spridgets 14
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
Rob Glasgow Brake/Clutch Reservoir Lines Austin Healey 9
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
D brake /clutch pedals Austin Healey 2
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
jlaird Brake and Clutch bleeding Spridgets 7
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
Lukens More clutch / brake master cylinder questions. Triumph 7
Rut Brake and clutch pushrod Spridgets 1
T BN1 clutch and brake shaft Austin Healey 4
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
richberman brakes/clutch fluid out top of brake reservoir Austin Healey 11
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
