TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations?
Tropical TR
My preference is to reuse the old master cylinders for my '59 TR3A and send them to Apple Hydraulics for sleeving. In taking a closer look, they are not identical castings. One is stamped "Girling 75" and the other simply "Girling" in smaller letters. Both have (as best as I can make out) the numbers "310680", although the latter appears to have "·02" added at the end.
attachment.php
Does anyone know if this is simply a case of the original being replaced somewhat later with a slightly changed Girling replacement, and which one would be closer to the original Standard-Triumph installed version?
Has anyone had experience with the Moss Classic Gold reproductions? I believe there was discussion several years back of some problems with those?
Appreciate any info.
Regards,
Walter
TomMull
T
Tropical TR
Hello Tom,
Thank you very much for this information. I will check it out and do appreciate your help.
Regards,
Walter
Geo Hahn
It was my understanding that the originals would have vertical ports (not the slanted) though I have no personal knowledge of that.
As for Moss Classic Gold -- aren't Girlings still available?
T
Tropical TR
Hello Geo,
To my knowledge, only the TR3/early TR3A had the vertical ports. Apparently TRW/AP Hill are producing a very similar if not identical version. Thanks!
Regards,
Walter
T
Tropical TR
Hello Art,
Thank you very much for this information. Odd that the other suppliers list some TRW (Girling) models, but not the one for the TR3A. Appreciate it!
Regards,
Walter
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
BOBBYR Girling brake booster Austin Healey 5
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
T Lucas girling brake pads Triumph 2
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
rr64 Wanted: Girling Brake Line Banjos Other British Cars 9
F girling master cylinder [brake] Austin Healey 3
A Wanted Girling Axle for TR2 Triumph Classifieds 5
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
R TR2/3/3A Girling Rear Brakes Triumph 9
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
S T-Series girling shocks MG 0
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
HerronScott Lucas and Girling Triumph 3
H Rebuilding Girling 16P Triumph 5
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
P Girling brakes on a Chrysler? Other British Cars 8
Z Girling/Armstrong lever arm shocks Spridgets 2
