Yes, but opinions vary on what it is. What I did was slide the boot partially over the piston, so the part that fits into the caliper recess was hanging off the bottom. Kind of stuff it into place, then hold the boot in the correct position while you push the piston through. As the piston bottoms, the boot will slip into the notch.
I've also heard stories of boots that don't quite fit right, so if it seems totally impossible, you may have some of those.
