TR2/3/3A 1958 TR3A missing on cyls 2 & 3
P
phantom132
This summer I had a problem of it missing on Cylinder 1 & 2 and it turned out the #1 float bowl wasn’t getting gas. Replaced fuel pump & gas line. No leaks anywhere.
Now car misses on Cylinders 2 & 3!
1. New plugs
2. New distributor cap/rotor (Pertronix Distributor)
3. Coil tested and seems to be good.
4. Compression 155-160 on one gauge, 175-180 on second gauge.
5. Swap hi-tension wires around, no change. Wires themselves are good.
6. Sparks are good.
7. Set valves.
Idles ‘well,’ but if I pull #1 or #4 plug wire it stumbles and dies.
Pull #2 or #3 plug wire, no change in idle.
The miss does not ‘wander’ no matter what’s done, just #2 & #3 cylinders. Checked wiring to coil and no breaks in insulation, etc.
NOTE: In addition to the fuel pump, also replaced Steering Box/Idler Arm etc. Just mentioning it.
Completely baffled. Any advice would be appreciated.
Thanks in advance.
P
phantom132
Forgive me stating the obvious, but double-check your firing order, which should be 1-3-4-2. It just might be that 2 and 3 got swapped around at some point!?
You're not the first. Sadly, all I can say is that I 'don't think' I touched the HT wires while doing the gas line. Will check again because it makes sense.
Thanks.
Sarastro
Are you using a side-entry cap? If so, those contact the high-voltage wire by puncturing it with a pointed screw. Those don't work well with the older type of resistor wiring, as the conductor is made of graphite impregnated string, and it's hard to make a good contact to it that way. Most modern wires have the resistor in the plug connector and use metal wires. You can check this with an ohmmeter. If you have the older type, the resistance will depend on the wire length.
Another option is to use solid-core wires and resistor plugs. It's hard to find nonresistor plugs today, anyway, so you might already be using them.
I have a top-entry cap with modern plug wires. I had planned to replace them with something more original, when I restored the car, but since they are good quality and give me no problems, I think I'll keep them.
JHaydon
It is old school but double check the "new cap" for flaws/cracks. Weirder things can happen.
Mad dog
+1
We had a batch of bad Pertronix caps a while ago. The issue has since been resolved, but not knowing when your cap was made, it's possible it could have come from that batch.
Steve, the Pertronix distributor cap uses modern plug-in wires so we should be able to eliminate that (I hope). But I have a piercing-type cap on another car so I am going to write that down for my own future reference!
mctriumph
If you blunt the piercing screws, you can get the resistance wires to work OK. HOWEVER , there is
now a real need for loctite on each screw, as the will come loose ,falling into the distributer . Nothing good
happens in the next millisecond when this occurs.
Mad dog
S For Sale 1958 tr3a Triumph Classifieds 0
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
2billydavies TR2/3/3A question about 1958 TR3a engine number, body number, etc Triumph 7
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
P TR2/3/3A 1958 TR3A Paint Colors & codes? Triumph 6
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
P For Sale 1958 sunbeam rapier convertible and hardtop (coastside/pescadero) Other British Classifieds 0
S 1958 100/6 Bumper Brackets Color Austin Healey 2
jfarris Immaculate 1958 Bugeye Spotted 4
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
A 1958 Triumph 6T restored British Motorbikes 5
doc50 For Sale 1958 Metropolitan Other British Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
N Please help --- New owner of a 1958 Austin Healey Sprite Spridgets 4
doc50 1958 Metropolitan Progress Other British Cars 4
doc50 1958 Nash metro door questions... Other British Cars 6
V TR4/4A Learned to drive in my father's 1958 TR3 58 years ago, never got over it Triumph 3
sim 1958 fuel gauge sprite Spridgets 11
M TR2/3/3A 1958 TR3 Project Triumph 85
dougie 1958 100/6 "s" Austin Healey 6
H 1958-1961 Austin Mini 850 speedometer housing pod British Motor Corp 3
maxwedge5281 1958 bn6 side curtains Austin Healey 26
F 1958 Meadows FriskySport Other British Cars 9
HealeyRick Goldie at Earls Court 1958 Austin Healey 1
sim 1958 sprite lug bolts Spridgets 8
madhouse 1958 100-6 VIN check [BT7 vs BN4] Austin Healey 7
F 1958 Frogeye with fuel problems Spridgets 9
P Bugeye #6519. 1958 or '59 Spridgets 3
CZ_Dave 1958 Chevrolet Delray Car B Que Other Cars 2
mgbmedic TR2/3/3A My 1958 TR3 project Triumph 6
R TR2/3/3A Where is my 1958 TR-3A? Triumph 0
J My 1958 Bugeye is on EBay. Spridgets 4
bighealeysource looking for a Jensen batch number for my 1958 BN6 Austin Healey 8
dougie 1958 Sebring Sprite Austin Healey 0
J Anyone interested in very original 1958 Bugeye? Spridgets 1
S Correct Generator for Austin Healey 1006, 1958 Austin Healey 9
W I got the 1958 100-6 home Austin Healey 21
sim 1958 ignition light ? Spridgets 5
ronzet 1958 BN4 Horns Austin Healey 1
ronzet 1958 AH 100-6 Torque Sequence Austin Healey 1
M 1958 Bugeye Up-date Spridgets 15
JodyFKerr Craigslist: 1958 BN4 Austin Healey 0
B 1958 Alpine Cup - vintage racing video Spridgets 4
M Redoing dash question for 1958 Sprite Spridgets 37
ronzet 1958 100-6 Seats Austin Healey 25
Brooklands 1958 Peerless GT Triumph 2
