Correct Generator for Austin Healey 1006, 1958
Johnny
Hi Stuart, the BN4's use a Lucas C45 PV-5 generator. Cutting in speed 1,100 to 1,250 generator rpm. Maximum output 22 amps, 13.5 volts at 1,700 to 1,900 generator rpm. A field resistance of 6 ohms.
All of the above came from the AH shop manual under "General Data".
Keoke
anthony7777 said:
stuart1006, why do you ask?,i sent you a p.m..
:savewave:
COZ!!
He wanted to hear from an authentic Healey source.--Keoke-- :angel:
5
57_BN4
After hunting for some replacement field coils recently I found that few auto electricians referred to starters and generators by their model number, preferring to use the Lucas part number instead.
The model number means something like C= concentric mounted, 45 = 4.5 inches field coil diameter, P = external regulator, V = ventilated, and this apparently doesn't always relate to the intended application.
The Lucas part number for 100/6 is 22483D and for the discerning generator owner will be followed by a date code somewhere around four to six months earlier than the build date of the car.
Andy.
S
Stuart1006
Member
Hi guys:
Thank you very much for your help. It seems I did something wrong the when I tried to reply before because the only thing that came out as a reply is HI guys.
Anthony7777: I just bought an 1958 Austin Healey 100 6 that I will start restoring in a short while. I do not belive the generator is correct, I think it was changed by a PO. I do not know what a p.m. is, so I can not say anything about it. I will probably need buy a correct generator for this car, preferably a used one to restore, but will consider a restored one if the price is right.
Thank you again.
Keoke
Stuart1006 said:
Hi guys:
:savewave:
Why guess~~~ "Andy told you in his post above what model number was specified for that car and the model number appears stamped into the case of a Lucas generator.
Check and see if it has one..
A-- p.m. is an off list message sent directly to your E Mail address from the forum by Anthony.
----------------------Check it and make sure--Keoke :frown:
Thank you again.
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
Jake Correct generator pulley and fan? Pics needed Austin Healey 5
TypeRboy Correct way to polarize a generator Restoration & Tools 7
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
