correct Dash board color
Joe Schlosser
We ( I am helping out) are just starting the assembly of a frame off restoration of a 1954 100-4.
The aluminum dashboard was black with a greenish color around the gages.
Both the black and the green will need to be redone.
What is the proper green for this area??
Is it available anywhere?
Healey 100
The dash color depends on the body color. I believe most of the dashes were originally two tone with silver in the raised area around the instruments. The remaining color depends on the body color. I think it is black for red or black cars, white for white cars, blue for ice blue cars and green for spruce green cars. There are probably other combinations, hopefully someone will chime in with more accurate details.
We carefully removed the original paint on the dash of our OEW BN2, and we didn't find any evidence of silver paint. Have heard that may be the case with later 100s--ours is a '1956'--or some 'oddballs' that came off the line. Also learned--too late to restore correctly--that ours was one of the BN2/100M cars that had the chassis painted black from the scuttle forward (we noted that the engine compartment was painted black, but assumed that was done by a DPO):
pan
There doesn't seem to be any hard & fast rule. My '54 BN1 was originally Healey Blue with blue trim. The dash was black with silver instrument area. When I restored the car in 2003, I painted the dash dark blue to match the trim. John Wheatley in England has a 100 that is often used as a benchmark as it is a one owner car. This Healey Blue car has a blue dash with no contrasting colour around the instruments.
Joe Schlosser
Joe Schlosser
Thanks for the information.
Car is a 54 and was originally one color red. It was repainted with the correct red.
The dash is black except around the raised area.
The raised area color could have been silver although it looks like a faded green.
The car has been sitting (apart in a garage) for at least 25 years.
I will be probably asking a bunch of questions here in the next couple of months.
bighealeysource correct dash paint/color on BN1 Austin Healey 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
