T-Series which way is correct
saltiga
My next question is, In my "T" series manual it says the dudgeon pin clamp bolt should be on the right hand side of the engine. It was in that position by my dismantling marks, When I look at a cross section of the engine in the manual it shows it on the left hand side(opposite to the cam shaft, and the oil hole is on that side of the con rod). Further along in the manual it says with the MG"B: it must face the cam shaft side. Its not an MG"B" engine but I have 2 ways of describing , the same thing, So do I stick with the original assembly with the clamp bolt on the same side as the camshaft, or do I install as per the manual diagram Not liking to take a punt what's the correct way. Saltiga
PAUL161
Unless someone comes up with a logical explanation why it should be changed from it's original position, I would put it back the way it came apart. Remember, MGT engines and MGB engines are different in design, I would not use any MGB info to rebuild an MGT engine. If you don't have one, get a rebuild manual or manuals for your engine. JMHO, PJ
Brinkerhoff
The RH side of the engine is viewed from the rear of the car looking forward, therefore placing the camshaft on the LH side. The gudgeon pin clamp bolts should be opposite the camshaft. The cross section of the engine in the manual is from the front looking toward the rear. A lot of great info can be found with a Google search " XPAG engine".
Sarastro
Definitely on the side opposite the camshaft. I don't know why it matters, but I assume there's a good reason.
Roger
Bronze
The clamp bolt should be on the Thrust side of the piston, so that the mighty force of the explosion doesn't try to open up the split in the con-rod.
That's the theory, as taught to me many years ago with reference to Austin Sevens, though true for all engines.
Assuming normal clockwise rotation (when looked at from the front) then the Thrust side is the Right side (when looked at from the rear). Position of camshaft is irrelevant, though handy for remembering.
Please do not ask why we speak of rotation from the front, side from the rear, or other arcane mysteries. They just are.
:smile:
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
Jake Correct generator pulley and fan? Pics needed Austin Healey 5
