TR6 Title with correct VIN
bonzocfi
Member
I'm having a problem getting the Louisiana DMV to issue a title with an 'O' as the last character. The title I received as a 0 instead. They say the US doesn't use an 'O' because of the confusion it could create. Does anyone have a title with the 'O' and if so, what is the state of issue?
Merlin63Tr4
My California registered Tr4 has "LO" as the last two characters of the VIN number.
Any Tr4 and I think Tr2-Tr3's that were originally equipped with OD will have "LO" as the last two characters of the VIN.
M.
2liter4cyl
Bronze
For a tr3, the number is followed by an "l" & "O". L means left hand drive, and if so equipped, O for overdrive (This British VIN how do you change it in USA?)
B
bonzocfi
Member
Merlin,
Yes, the O is for overdrive. But the Louisiana DMV will not issue me a title ending in an O. Does your CA title have LO on it?
I want to be able to tell the DMV that other states use the O. BTW, I lived in Milpitas from 1980-1991. Was stationed at Moffett Field.
CraigC
What you need to do is point out to the DMV personnel that prior to 1981 there was no restriction on the use of the letters "I" and "O". If your car is older than that, there is no reason for them not to issue a title with the correct VIN even if it contains an "O". You may have to go to a more senior employee at the DMV office to push this through.
Geo Hahn
My TR4 was originally titles (Hawaii) with a '1' on the end rather than an 'L'. Possibly because they didn't like a letter there, possibly because a typewriter lower case L is more or less identical to a one. When I retitles the car in Arizona I took in some documentation (probably Piggot) and convinced them that it was an L.
Merlin63Tr4
Bonzocfi,
Yes, the California pink slip for my '63 Tr4 has "LO" as the last two characters of the VIN.
I dug the pink out of the safe and just verified it.
Milpitas has really grown since you left.
Moffett Field is kind of a ghost town since the Navy left.
We are still waiting for GOOGLE to finally get the approvals/permits to re-skin Hangar 1.
D.
B Lost Title Woes Restoration & Tools 9
AHS Spitfire 1966 Spitfire with title for parts Lancaster PA NFI, $100 Triumph 3
L T-Series 1952 MG TD2 Title from the USA MG 7
NutmegCT General TR no title or registration? Triumph 22
J New Member, Year of Manufacture/Title Question Austin Healey 9
dudley32 How to change or edit title on a thread FORUM Navigation Questions 2
E TR4/4A Triumph TR 4 Title issue Triumph 7
Steve P. Need Bugeye vin tag & title Spridgets 15
pbraun Door pillar number used as VIN on title. What to do? Spridgets 11
HealeyRick Sprite Title Problem Spridgets 8
5 The Title BUGEYE or FROGEYE for that matter Spridgets 15
S Title Search Restoration & Tools 14
J I love this title Other British Cars 14
Hot Wings Title for a tub? Spridgets 9
P TR6 Extra digit in title Triumph 8
BoyRacer Needed: A title for a BN7 Austin Healey 23
M Title & Transport Question Spridgets 6
NutmegCT No title, registration in California? Triumph 10
B TR6 Advice on TR6 potential purchase and title Triumph 26
Jim_Gruber Dealing with a missing Title Spridgets 24
eschneider value - BJ8 frame, engine, trans w/ title? Austin Healey 8
T MGA Anyone have an MGA VIN/title I can buy? MG 25
BLG Salvage Title??? MG 6
jlaird Working title: MGs everywhere. MG 5
T Wanted Griffith 200/400 and/or title TVR 11
B Title: AH Carpet installation video? Austin Healey 11
G Title help Triumph 9
PAUL161 The 70 went back! Complicated Title Problem MG 11
H Title or Registration MG 9
J Off Topic Title Question... MG 5
Stinky TR6 Got the title to my TR6 Today Triumph 3
Steve P. Bugeye title needed Austin Healey 3
D Title Companies MG 9
P 64 mini title & vin British Motor Corp 2
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
