Correct Brake Caliper colour
robolab
Hello,
I want to restore my brake calipers. What is the correct (original) colour for the BJ8 MKIII ?
Deleted member 19315
Hi, I expect that originally they were cadmium plated, I believe this finish is now illegal to apply at least here in the uk. It used to fade down to a dull silver bronze. I've used zinc plating with a pale yellow passivate to try to replicate cad in the past. It starts out a bit bright but does tone down over time. I'm pretty sure they are not originally painted parts, but as ever happy to learn.
Andy
drambuie
Yes I agree, just use the wire wheel paint, It looks correct even though the factory may not have painted the front calipers in the first place. A very good alternative for the correct wire wheel paint is sold by Eastwood, it's called Detail Silver part # 100042 moss also sells the correct wire wheel paint which is very high quality but a bit pricey.
steveg
Eastwood appears to no longer stock Detail Silver; also 100042 or 10004Z search comes up empty.
Do a search here for the previous thread: "Paint code spoke wheels?"
Scroll down for a Duplicolor aluminum that is supposed to be good.
BigGreen
I am used to make a copy of information like that
Found this ; Brakedrum colour Duplicolor Cast Aluminum 500
steveg
As usual, MGA Guru comes through:
https://mgaguru.com/mgtech/paint/pt104.htm
Detail Silver - Eastwood
Ditzler 2593 (Argent Silver)
" DAR-2593 (acrylic enamel)
" DDL-2593 (acrylic lacquer)
Ford Silver - DAR-2593 (Ditzler Argent Silver)
Ford Silver - PPG - DCC2593 polyurethane (PPG Argent Silver)
Ford 1G - "Silver Poly" (1975-1976)
Ford 1G - "Silver Metallic" (1977-1980)
Hammered Silver - Ditzler DAR 2593
Hammered Silver - Dupli-Color® FM-149
High Performance Wheel Coating - Dupli-Color® - WP101 (silver)
High Performance Wheel Coating - Dupli-Color® - WP103 (clear overcoat)
Jewel Silver - Subaru code 9985
Metallichrome Aluminium - ICI no: P0-2358 (original paint, see note below)
Moss Silver wheel paint - 220-560 (Moss Motors Ltd)
Silver - Ditzler Delstar® - Code #16
Wheel Paint - VHT - SP188 polyurethane (Argent Silver)
drambuie
I believe the replacement for Eastwood detail silver is now called Argent silver part # 1000-1 they list it as Muscle car area wheel paint. I never used it so can't speak for its correct silver color, however other British car enthusiast postings have recommended it. I still prefer moss wheel paint because of its quality and proper silver color. Takes about 3 days to dry but well worth it. I highly recommend applying a semi gloss clear coat over the new silver paint for longer lasting durability.
Just as a side note: I noted Eastwood does list some basic Ac Delco parts for Austin Healey, such as front brake caliper rebuild kits for 3.99 brake hoses, brake rotors, fan belts regulators, urethane bushings ect... Something to put in your memory bank!
Not original, but if you have chrome spokes and rims painting the calipers and drums black makes them stand out. With painted I'd go with the silver.
R
robolab
Thanks for all good replies, so i will look to get dull silver Brakecaliper colour or corresponding wheelpaint in Germany
M Dunlop Brake Caliper correct color? MG 2
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
5 Correct rear brake cylinder size Austin Healey 1
Basil COrrect plating for Brake Booster? Jaguar 9
drooartz Brake M/C install -- correct? Spridgets 0
A Emergency Brake Handle Correct Reassembly Order ? Austin Healey 2
hondo402000 Correct Brake fluid ? Triumph 11
J Coil spring free length & correct brake servo? Austin Healey 2
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
