Dunlop Brake Caliper correct color?
billspohn
All mine have been a rusty red. :jester:
Actually, I believe they were an off white originally, but don't ask me to prove it. Personally, if I bother to paint them, I use Machinists Gray - looks like a new casting.
Grantura_MKI
Bill is close. I use a colour they call "cast blast". Looks like new cast metal as your bits return from the machine shop. No probel with heat, etc and last years.
Cheers,
D.
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
H TR2/3/3A Original Dunlop 5.50X15 Bias Ply Tire Data Triumph 4
madhouse Need Dunlop 165/R15 tires Austin Healey 8
AUSMHLY Dayton vs. Dunlop wire wheels Austin Healey 11
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
J TR2/3/3A Dunlop wheels, tube or no tube? Triumph 3
WME MGB-GT Dunlop SP20 FE MG 11
H Dunlop D-Type wheels Austin Healey 29
K Original "old" 1960'es Dunlop wire wheel paint code Austin Healey 7
K Original 1960'es Dunlop wire wheel paint code Jaguar 7
K 1960'es Dunlop wire wheel paint colour code Restoration & Tools 0
K General Tech 1960'es Dunlop wire wheel pint colour code Triumph 13
MadMarx Morgans catched by Triumph - on Dunlop racing tire Triumph 2
J Dunlop L Racing Tire "Break In"? Racing 9
R 2 new dunlop silver wire wheels with hubs 4 sale Triumph 0
M 100/6 1957 Dunlop disc-brakes Austin Healey 25
T Free Dunlop Gold Seal 5.20 13 bias ply tyre Spridgets 5
M Dayton or Dunlop Wire Wheels ??? What is best Austin Healey 44
B TR6 Dunlop 72 spoke wire wheels TR6 Triumph 6
pan Dunlop Wire Wheels Austin Healey 10
LuckyLuke classic dunlop aluminum disc wheels for e-type Jaguar 2
Patton How to tell Dunlop or Dayton Austin Healey 16
C Any Experience with Dunlop SP20's Austin Healey 1
Slider748 Wire wheels: Dayton vs Dunlop Triumph 5
DerekJ Dunlop Racing Tyres Austin Healey 6
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
