The correct tool does make it easier [fill steering rack]
drooartz
Finishing up some work on my Morris Minor (same rack as a Spridget) and I decided to hunt down a correct tool to use to fill the rack with oil through the zerk fitting. I've tried a few workarounds over the years, but nothing ever worked all that well. After some Googling I found this:
Push Type Oil Gun with Hydraulic Tip
https://www.amazon.com/gp/product/B01N0AR9L0/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Didn't find any other options and I was on a bit of a time crunch, so went ahead and bought it. And ya know what, it did exactly what it said on the tin. Filled the little gun with oil and it pumped it right into the rack. No mess, muss, fuss, or bother.
It's not cheap for what is essentially a once-a-year use tool, but I do have to admit that it worked perfectly for the job. Glad to have it in the toolbox.
Rut
Drew,
Good find! I’ve been using corn head grease since it’s flowable and can be used in a regular grease gun, but this should be a better option.
Thanks, Rut
Jim_Gruber
And Drew bought the last one. Out of stock.
nomad
Any regular grease gun will pump 90wt or 140wt oil. Just unscrew the plunger part and keep the tube upright and they work great. I have an old gun that I keep without a plunger just for the steering rack.
Drew, that gun will work for the other grease zerks on your car as well and there are plenty of them. I grease the front suspention at every opportunity since it is expensive to repair and not long lived.
Kurt
drooartz
drooartz
I tried that method in the past, but just managed to make a mess. Likely my fault somewhere in the process. This one made it a no brainer, always a good call for me. :grin:
I've got a regular grease gun as well to use on the grease zerks. Part of my spring servicing on each car.
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
Jake Correct generator pulley and fan? Pics needed Austin Healey 5
