Girling/Armstrong lever arm shocks
zblu
got a load of mixed parts for my healey, amongst the bits are a pair of these that are way to small for the healey, before i throw them thought i would ask if they of any use to anyone, need a total rebuild
Jim_Gruber
If they are Spridget Stuff Peter C. will want them
He might work out a deal for core value for other Healey Shocks. Drop him a note
nosimport@mailbag.com
> Peter Caldwell
> World Wide Auto Parts
> 2517 Seiferth Rd., Madison, WI 53716
> (800) 362-1025 Fax (608) 223-9403
A Wanted Girling Axle for TR2 Triumph Classifieds 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
R TR2/3/3A Girling Rear Brakes Triumph 9
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
S T-Series girling shocks MG 0
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
HerronScott Lucas and Girling Triumph 3
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
H Rebuilding Girling 16P Triumph 5
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
BOBBYR Girling brake booster Austin Healey 5
P Girling brakes on a Chrysler? Other British Cars 8
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
T Lucas girling brake pads Triumph 2
davelgee Girling MK2a vacuum servos? Other Cars 31
Scott_Hower Girling Red Rubber Grease? MG 1
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
