The Girling Company?
Number_6
Racetorations in the UK sells a dual brake master cyl kit. They're near the bottom of the page. Kind of pricey though. I've thought of getting one for my car.
TR3 Dual brake master kit.
eschneider
trw-eos owns the remnants of Girling. They have an online catalog at www.trwaftermarket.com (click on the catalog tab at the top of the page). Once in the catalog you can search by girling number.
You should be able to order anything on the TRW page through British Parts Northwest - I think they are the largest US supplier for these parts.
There is another company that is re-popping Lockheed stuff, but the web page escapes me at the moment.
martx-5
Here's a link for the dual master set-up I've been working on. Hard to believe it was over four years ago I started this project. I think this thread has just fired me up to make the necessary changes in the system as discussed in the thread and turn this into reality. :driving:
A Wanted Girling Axle for TR2 Triumph Classifieds 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
R TR2/3/3A Girling Rear Brakes Triumph 9
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
S T-Series girling shocks MG 0
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
HerronScott Lucas and Girling Triumph 3
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
H Rebuilding Girling 16P Triumph 5
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
BOBBYR Girling brake booster Austin Healey 5
P Girling brakes on a Chrysler? Other British Cars 8
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
Z Girling/Armstrong lever arm shocks Spridgets 2
T Lucas girling brake pads Triumph 2
davelgee Girling MK2a vacuum servos? Other Cars 31
Scott_Hower Girling Red Rubber Grease? MG 1
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
