TR2/3/3A Girling 10" Rear Brakes question
TR4nut
Last weekend I helped a friend redo his rear brakes - 10" Girling setup. I thought I was qualified enough to help because I had done this last year for my pre-60K TR3A project. I think I may have done it wrong, however - both my project car, and his car had both steady posts as well as spring loaded shoe retaining pins. The steady posts were unique to the Girling 10" setup and I've not seen a writeup on them.
So questions:
1) Is there a factory manual out there describing the 10" drums with the steady posts?
and
2) Were both of these cars incorrectly setup since they had both steady posts and retaining springs? I thought that was normal but looking at the Moss offerings it looks as though the steady posts were the only thing that should have been there - not the retaining pins. Is that right? Seems a little confusing because there are holes in the backplate as well as holes in the brake shoes that work nicely with the retaining pins.
Thanks
Randy
Geo Hahn
Mine (TS47905) had both... but I only had 3 of the 4 spring doo-hickeys so I omitted all of them and just used the steady post. No problemo.
TR4nut
TR4nut
Thanks Geo- my theory is building that there are a significant number of cars around that commission number that we equipped with both. My commission is just under 46000, my friends is in the 47000 neighborhood (not being secretive, just can't remember the exact numbers). Your car makes it 3. Seems too coincidental to just be a previous owner thing.
From reading around on the subject I do know Don Elliot only has steady posts on his 10" brake setup - but I think Don's commission is a bit earlier too.
TR3driver
Great Pumpkin - R.I.P
Interesting. One of my previous TR3As had the posts and no hold down springs, but I don't recall the commission number offhand. Seems like it was around TS42xxx. It had a really strange clunk that I eventually traced to the post not being properly adjusted ... when you applied the brakes, the shoes would walk out to match the drum, then fall back with a clunk a second or two after releasing them. There were extra holes in the shoes, but I don't recall any extras in the back plates.
TS39781LO should have had posts, but had the later 9" brakes installed (with springs) when it came to me.
No evidence in the SPC of the hold-down springs being fitted along with the posts.
Jerry
I just did my 10 inch and they have the posts but no retaining pins. But, the springs in the back don't hold one side quite tight to the rear plate, causing some scraping on the drum. So the retaining pins might be a good add to the system. I am going to run it a bit and see what is rubbing (should show some shiny metal) prior to decision on the retaining pins.
Jerry
TR3A post 60000
TR3driver
Sounds like you might have the springs in wrong, or they are distorted. On mine, they pulled the shoes firmly against the back plate (and there was even a fair amount of wear at the contact points).
Jerry
possible, but I could not figure out another way to install the springs. Both are in the back of the shoes, smaller one on top.
Jerry
TR4nut
TR4nut
Jerry-
Was your car modified by a previous owner? For a post-60000 car I'd expect you'd have 9" drums, and the normal retaining pin setup with no posts.
Randy
Jerry
Randy,
that is VERY possible. The PO has done many changes. I have Type B calipers on the front, 10 inch on the back, A TR4 engine as per the serial number. The car came with two 40 DCOE weber, but not installed in the car. So, not an original car. I keep thinking about your thought that the springs are not installed correctly, I just don't see another way to do it unless there are other holes to put the springs. But I will check. Thanks for the suggestion.
jerry
Geo Hahn
...I could not figure out another way to install the springs. Both are in the back of the shoes, smaller one on top...
Are we all talking about the same springs?
I thought the discussion was retaining springs (127-129) vs steady posts (130-132):
One would think that only one or the other was needed but (as noted above) at least some cars seem to have both.
Jerry's comment "smaller one on top" sounds like he means the springs that pull the shoes back from the drum (124 & 125) though the smaller/shorter is on the bottom.
TR3driver
Little bit of thread drift here. I believe Jerry was talking about the return springs; as on most 10" with the posts, the return springs are the only thing holding the shoes against the posts.
It's been too long, I can't quite remember. Does anyone else have return springs where the ends turn outward on the front side of the shoes, instead of inward? They're shown that way in the back of the Bentley.
Geo Hahn
... Does anyone else have return springs where the ends turn outward on the front side of the shoes, instead of inward? They're shown that way in the back of the Bentley.
If you mean -- does the spring hook into the shoe from behind so the tip of the hook is visible when the springs and shoes are installed -- then yeah, that how mine are.
I always install the springs on the shoes then stretch the pair of shoes into place. No idea if that is the right way or even the best way, just works better than diddling with each spring after the shoes are on.
Sure wish I had taken some pics the last time around.
TR3driver
Actually, I meant the ends of the springs are shaped like this diagram (from the workshop manual), rather than like the one you posted
I agree about it being much easier to install the springs on the shoes first, and then the shoes onto the backplate.
TR3driver
Well duh ... I did take some pictures, just forgot about them. Here's a shot with the springs installed (properly I think)
and the bare back plate where you can see the pegs (barely) and the lack of extra holes
Geo Hahn
Don't know if this photo helps?
Well, it helps me feel bad about how grotty mine look.
I do now see the difference in springs Randall mentioned. Yours hook onto the hole (like one might expect) rather than reach thru and rest against the shoe (like in Randall's photo).
BTW -- Have you noticed that your car is upside-down?
TR3driver
Are those even 10" brakes? I thought the folded hold down springs and smaller adjuster assembly were part of the 9" versions.
TR4nut
TR4nut
Those look like 9". Adjusters for sure are 9" style, not like the bulkier 10" version. And very nice 9" I might add, I agree with Geo's comments!
The 10" drums I just set up have the springs turned down like Randall shows. Only difference is I've found spring retaining clips in addition to the steady posts.
R TR2/3/3A Girling Rear Brakes Triumph 9
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
A Wanted Girling Axle for TR2 Triumph Classifieds 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
S T-Series girling shocks MG 0
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
HerronScott Lucas and Girling Triumph 3
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
H Rebuilding Girling 16P Triumph 5
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
BOBBYR Girling brake booster Austin Healey 5
P Girling brakes on a Chrysler? Other British Cars 8
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
Z Girling/Armstrong lever arm shocks Spridgets 2
T Lucas girling brake pads Triumph 2
davelgee Girling MK2a vacuum servos? Other Cars 31
Scott_Hower Girling Red Rubber Grease? MG 1
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
