TR2/3/3A Girling axle disassembly for shipment
2long
I am looking at shipping a complete Girling rear end to Hawaii, including axle tubes and backing plates/drums.
Wondering if the axle tubes can be taken off the differential to make shipping more compact? It has to be air freight as it's crossing an ocean.
The shipping cost is likely to exceed the cost of the item, but I am trying to minimize cost.
Dan
charleyf
Dan,
Yes, simply a matter of removing the six bolts from the inside of the brake backing plate on each side. Then you can draw the axle shafts out and remove the brake backing plates. But that is as far as the disassembly goes. Be sure to remove the oil from the differential prior to removing the axle shafts. You should mark each axle shaft and brake backing plates as right or left, for reassembly.
Charley
2long
Thanks for the reply Charley. So the axle tubes don't come off the differential? If so, I guess I should just leave the axles in the tubes?
Dan
TomMull
That's what you get when you live on an island paradise. I'd ship it intact. The only thing I'd add is that Charlie's right about the oil. Most shippers are pretty fussy about that.
Tom
Geo Hahn
As I recall those tubes are swaged or staked in a fashion that doesn't look like it should be undone nor would it be easily replicated.
In addition to the left and right parts noted, be sure to keep the shims separate and labeled for L & R as they will probably vary in thickness and number.
CJD
The tubes CAN be removed, but the trouble/cost of having them re-installed would likely exceed the difference in shipping...unless you are willing to tackle the aligning and re-welding to get them back on yourself. I doubt removing the axles and brakes would be worth it either, as you only save a few inches.
charleyf
Dan
Agreed, just leave it intact with the oil drained. Then you don't have to be concerned about shims, right and left parts . You also won't lose any parts if it is one piece.
Charley
A Wanted Girling Axle for TR2 Triumph Classifieds 5
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
R TR2/3/3A Girling Rear Brakes Triumph 9
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
S T-Series girling shocks MG 0
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
R Girling vs other wheel cylinders Austin Healey 10
H Problems with Girling master cylinder Austin Healey 8
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
HerronScott Lucas and Girling Triumph 3
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
H Rebuilding Girling 16P Triumph 5
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
BOBBYR Girling brake booster Austin Healey 5
P Girling brakes on a Chrysler? Other British Cars 8
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
Z Girling/Armstrong lever arm shocks Spridgets 2
T Lucas girling brake pads Triumph 2
davelgee Girling MK2a vacuum servos? Other Cars 31
Scott_Hower Girling Red Rubber Grease? MG 1
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
