TR2/3/3A Newbie Question regarding Girling rear brake cylinder
Andrews
Hello All,
I am brand new to Triumph ownership (And to be honest, car maintenance as well) and am working on the Girling rear brakes of my TR3A. I could feel that the car was having a stuck brake or brakes so I got it onto jack stands and determined that the driver's side rear wheel was locked... The rear brake cylinder piston seemed to be jammed (I even saw a little bit of corrosion in the bore along the piston head). I assumed the cylinder was the problem.
I ordered a new drum, cylinder, brake adjuster, flexible hoses and shoes and springs (I had everything apart anyway). However the pistons in the new cylinders don't move freely as I thought they would by hand... I don't want to rebuild the entire system, just to find that I haven't addressed the actual problem.
Question is how freely should the pistons move in the wheel cylinder? Or can they only be accurately tested with hydraulic pressure applied?
I appreciate the patience with my elementary questions!
TRopic6
Hi Andrews,
My experience is the pistons are pretty hard to get out by hand; I use pliers to twist & pull straight out. I guess the seal needs to be tight to ensure no leaks. The rear brakes are simple and a good place to learn the joys of home auto mechanics. They were one of the first things I rebuilt on my TR4 in 1977. Welcome!
Jeff
TR3driver
Great Pumpkin - R.I.P
New ones can be rather stiff, especially before they get fluid in them to help lubricate the seal. They'll loosen up with a bit of wear.
Since you're a newbie, be warned that most of the diagrams in the manuals (and many web sites) show the wrong order of assembly when assembling the wheel cylinders to the backing plate. The text in the back of the factory TR2/3 workshop manual is correct, but the illustration is wrong.
RefittingGirlingrearbrakecylinders.jpg~original
A
Andrews
Hi Jeff,
Thanks for the reply... I won't worry too much about them then... I'll assemble the rear brake and figure that with the hydraulics hooked back up, they will operate as advertised. So far it is very enjoyable working on the little car!
Kurt
A
Andrews
Thanks Randall! I have found the diagrams to have great detailed photos of parts, but a little short on proper assembly... Disassembling everything has been the greatest help in determining proper assembly. I will definitely use your attached procedure for reattaching the cylinder plates (I bought a new set of those as the old ones were pretty rusty). This car is certainly teaching me patience!
Kurt
SteveBones
Hi Andrew,
Glad to hear you have jumped into the world of Triumph ownership. I wanted to let you know the folks that help, are extremely experienced and knowledgeable. I have ask quite a few questions along the way and I have been more than expressed with the help provided. Good luck and enjoy!
Steve
R Hello all and a question for a newbie... Austin Healey 13
60TR3A Dumb Newbie Question Austin Healey 16
skelly Quick question from a newbie Spridgets 10
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
A GT6 GT6 Newbie question Triumph 6
T TR2/3/3A TR2 question from a newbie Triumph 6
T Newbie SU Carb Rebuild & Restoration Question Triumph 31
T Newbie question about hoodstick cover installation Triumph 10
J jack's newbie question of the day-increasing comp Triumph 22
M Newbie question about charging system Spridgets 9
X a newbie question Jaguar 4
G a question only a newbie would ask Spridgets 16
S T-Series newbie with a clutch question for a 68 MG 0
S newbie with a clutch question for a 68 Spridgets 9
C Charging system-stupid newbie question Spridgets 63
P Newbie, first question? MG 17
G Newbie with a question Triumph 5
C Stupid Newbie Question Spridgets 4
B Newbie question--XK8 owners Jaguar 3
goloch Newbie Rust Question MG 14
M Newbie question Spridgets 22
C Newbie Tech Question- Weber Carb Spridgets 10
JoeC TR6 Another newbie TR6 question Triumph 9
Moose33 another newbie question- carbon canister MG 6
J Newbie intro and battery disconnect question Spridgets 10
Moose33 newbie question about HIF's MG 2
D newbie question bj7 Austin Healey 8
S Newbie Question MG 3
G Newbie with instrument repair question MG 3
F Newbie Hardtop Question MG 7
norcalnewb Newbie Intro and Question MG 7
B Battery question from a newbie MG 5
jerrybny Fuel Question from newbie Triumph 58
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
steveg TR6 Newbie looking for hopup guidance Triumph 15
njunear Newbie - to this forum, that is........ Austin Healey 8
S TR2/3/3A Newbie Triumph 15
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
D aspiring AH newbie: some questions Austin Healey 16
steveg Newbie questions on pulling an engine Austin Healey 19
S MGB Newbie 1978 MGB questions MG 11
5 Newbie looking at a '67 Austin FX4 Taxi... Other British Cars 15
T Newbie Bugeye Sprite owner engine advise needed Spridgets 5
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
S MGB-GT Newbie researching MGB GTs MG 28
S General TR Newbie looking for 2+2 Triumphs and other makes Triumph 15
Steve P. Newbie with more questions Racing 8
