Newbie Bugeye Sprite owner engine advise needed
tim66ah
Hi all, I recently purchased a 59 sprite with loads of spares. My car is drivable, but needs exterior painted and a few things sorted. I need to correct transmission problem of having smooth case shift lever in rib case. Will swap shift towers to correct this and look stock.
I have several 948 engines with this car. One is rebuilt with flat top pistons and 12H185 head. Does anyone know what my compression my be? I did compression test cranking it over and came up with 125-130 readings.
This engine has hs2 carbs.
The current engine in car is 90 psi and is 8.3:1 as stock.
I would like to swap engines while I'm at the transmission.
AN5Sprite
The only head casting numbers I can remember off the top of my head are the 12G202, 12G206 and 12G295.
I wouldn't hesitate to drop in the engine with the higher compression readings. I'm not going to speculate what the CR is, but I doubt it's too high for pump gas. I bet it's just fine and it will sound great!
racingenglishcars
Unfortunately, contrary to opinion, the compression readings by gauge don't reflect the compression ratio. This had to do with the inlet valve closing angle. The inlet valve closes at somewhere around 100 degrees before tdc. At this angle, the piston has already moved up the bore a bit less than half way. What air is left in the cylinder is then compressed to fill your compression gauge.
By comparison the calculated compression ratio has to do with total displacement (stroke times bore) theoretically fitting into the combustion chamber within the head and the piston dish.
At very low engine speeds (cranking) the difference is large, though with the dynamics of airflow at higher engine speeds this late inlet valve closing allows more air to enter the cylinder.
Camshafts are thereby tuned to specific engine speed ranges.
My compression ratio program is a bit helpful for figuring out what you have and need.
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
steveg TR6 Newbie looking for hopup guidance Triumph 15
njunear Newbie - to this forum, that is........ Austin Healey 8
S TR2/3/3A Newbie Triumph 15
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
D aspiring AH newbie: some questions Austin Healey 16
steveg Newbie questions on pulling an engine Austin Healey 19
S MGB Newbie 1978 MGB questions MG 11
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
5 Newbie looking at a '67 Austin FX4 Taxi... Other British Cars 15
S MGB-GT Newbie researching MGB GTs MG 28
S General TR Newbie looking for 2+2 Triumphs and other makes Triumph 15
R Hello all and a question for a newbie... Austin Healey 13
Steve P. Newbie with more questions Racing 8
Steve P. Newbie with XJS...opinions wanted Racing 9
B TR2/3/3A Newbie in need of help TR3 Triumph 11
60TR3A Dumb Newbie Question Austin Healey 16
skelly Quick question from a newbie Spridgets 10
Willie_P Newbie HELP: TR 3/4 leaf spring/axle installation Triumph 11
Henson80MGB Newbie w/ low fuel pressure issue MG 11
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
A GT6 GT6 Newbie question Triumph 6
stretchit2 HAPPY NEW from a Newbie Austin Healey 3
M Newbie: Just Checking In MG 7
B TR2/3/3A 57 TR3 Newbie...No spark? Basket case Triumph 31
R Newbie with Carb questions... Spridgets 12
R Newbie with carb questions... Austin Healey 11
M Help to the newbie - Diff Whine Austin Healey 16
Reginald Newbie from West Coast, NY, & Caribbean. '80 LE MG 7
M Newbie still puzzeled about flooding carb MG 6
G T-Series Newbie '51 MGTD MG 2
T Newbie Midget owner Spridgets 28
T TR2/3/3A TR2 question from a newbie Triumph 6
T Newbie SU Carb Rebuild & Restoration Question Triumph 31
D NEWBIE Triumph 38
jvandyke newbie pulls motor radiator bolts? Spridgets 18
EastBoundJoe Welding newbie Spridgets 39
sobamaflyer Newbie - please help with first drive impressions Spridgets 19
crya HELP! Newbie needs to know how to remove HUBS. Austin Healey 2
Mg_Bizzle Lowering blocks and front sus [newbie fitting q's] MG 20
Lukeee Newbie! Spridgets 5
T Newbie question about hoodstick cover installation Triumph 10
J Hello. Newbie here. Spridgets 35
J jack's newbie question of the day-increasing comp Triumph 22
69sprite Newbie Spridgets 7
M Newbie question about charging system Spridgets 9
