Newbie question about hoodstick cover installation
TFR
Bought a hoodstick cover from Moss for my 1960 TR3A. Of course they always assume you are replacing one so no instructions. Since I didn't and don't have one I am at a lose as to the installation procedures.
I have some photos I took at a car show this week end but I didn't ask anyone to remove theirs so I can see it in the finished form.
Any help would be greatly appreciated.
Geo Hahn
A couple of answers before you even ask...
The strangest bit is the Lift the Dot that is on the edge that tucks up under the hoodsticks. It finds a LTD peg on the capping along the back. If you do not have this peg in place you will need some pics or measurements.
You want it to fit so that those pockets at the front corners catch the folded hoodsticks... that is what keeps the thing in place at 80 mph.
The fit (on mine anyway) was abit loose for my taste so I lay a rolled-up hand towel among the center area of the sticks and a rectangular piece of foam along each side. All are hidden by the cover but they fill it out so it sits nice.
NutmegCT
In addition to George's explanation of those two pre-installed LTD snaps, another big help for me was a general outline of how to fit a new tonneau cover on an MGB:
https://www.mgexperience.net/article/tonneau.html
I used that technique as a model for my hoodstick cover installation. I lay the new cover across the sticks and used chalk to mark the center, both on the cover and on the car itself. These marks helped me keep the cover centered as I mounted the LTD snaps.
Assumption is that all the LTD studs are already mounted on your car.
I'd feel where the LTD stud touched the cover, and I'd mark that point with chalk. Then I'd cut a 3/8" hole (steel punch) at the chalk mark, and mount the LTD snap per the MGB article. I'd alternate from side to side, keeping the cover centered. You can buy a LTD punch for $37 (or $75), but I did it manually. Took about an hour to complete the job. Actually looks pretty good I have to admit.
Tom
T
TFR
Re: Newbie question about hoodstick cover installa
I hope I haven't ruined the cover but I installed the "lift the dot" snaps in the cover as I did the top. The cover just won't fit over the sticks when attached.
Some pics would help if anyone has any. On the car, before attaching to the car, installation pics.
If you need to send them to my email of TFRACING1@YAHOO.COM
Thanks!
NutmegCT
Hmmm ... you say "the cover just won't fit over the sticks when attached." Weren't the sticks in place when you first installed the hoodstick cover?
Maybe a pic of your cover attached to the car can clear up what you mean, so we can see what isn't fitting.
You mentioned "I installed the LTD snaps in the cover as I did the top." The top and the hoodstick cover are two different things (last I checked ...). Do you mean you tried to match the placement of the LTD snaps to the snaps that were already on the top?
Tom
T
TFR
I haven't been around British cars in 25 years. I had a Sunbeam Tiger, Austin Healey 100-6, MGs, Tr6 and so on. Then I started drag racing motorcycles. Last summer when I saw a good friend wreck and I am 51 I thought if I had wrecked I would be hurt for the rest of my life if not killed. So I sold all my race stuff.
My son found my 1960 TR3A in a garage that had been sitting literally for 28 years. I bought the car for $800.00. Now I have completely restored the car. I did all the engine, frame, body, paint, you name it all by myself. But during the course of restoration I had some questions. There were a few things I wasn't sure on how to install. One was the vent door and the other the hoodstick cover. The vent door I had on the car was broken so after I saw a working door it was easy to install. The hoodstick issue is as posted.
Now...
What I meant on my last post was that I measured the center and then marked the locations of the pins. Then I installed the LTD fasteners. Perhaps I installed them in the wrong location or what ever...I need some various pics of the cover and perhaps a simpleton installation instructions.
NutmegCT
OK - here ya go. Hope this is what you're looking for.
https://www.mgexperience.net/journal/tmorehouse/1406
The steps I followed are in the third reply above. Just a thought - be sure you've fully lowered the hoodsticks. Note how far down they are in my third picture. Maybe that's why your cover doesn't "fit"?
Tom
Geo Hahn
Here's some photos from mine. Similar to Tom's except 1) the second one shows the hidden up-side-down fastener 2) Tom is missing one LTD peg (the one that goes thru the plate holding the back of the webbing and 3) [most significantly] my photos are NOT posted to a site named "The MG Experience"...
T
TFR
Well... As I said I'm not fully familiar with the TR3.
My sticks stopped tightly and I thought they were down. So I couldn't figure out why the cover wouldn't stretch over the sticks. After I got home from work I studied the situation and discovered the sticks not down all the way.
Guess your saying, what a dumb @$#... I deserve it (smile).
Thanks for all the posts and help. I knew I couldn't be too far off.
This is a great sight and I am glad Glen Austin told me about it last week end. Thanks to all.
I feel very welcome here.
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
R Hello all and a question for a newbie... Austin Healey 13
60TR3A Dumb Newbie Question Austin Healey 16
skelly Quick question from a newbie Spridgets 10
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
A GT6 GT6 Newbie question Triumph 6
T TR2/3/3A TR2 question from a newbie Triumph 6
T Newbie SU Carb Rebuild & Restoration Question Triumph 31
J jack's newbie question of the day-increasing comp Triumph 22
M Newbie question about charging system Spridgets 9
X a newbie question Jaguar 4
G a question only a newbie would ask Spridgets 16
S T-Series newbie with a clutch question for a 68 MG 0
S newbie with a clutch question for a 68 Spridgets 9
C Charging system-stupid newbie question Spridgets 63
P Newbie, first question? MG 17
G Newbie with a question Triumph 5
C Stupid Newbie Question Spridgets 4
B Newbie question--XK8 owners Jaguar 3
goloch Newbie Rust Question MG 14
M Newbie question Spridgets 22
C Newbie Tech Question- Weber Carb Spridgets 10
JoeC TR6 Another newbie TR6 question Triumph 9
Moose33 another newbie question- carbon canister MG 6
J Newbie intro and battery disconnect question Spridgets 10
Moose33 newbie question about HIF's MG 2
D newbie question bj7 Austin Healey 8
S Newbie Question MG 3
G Newbie with instrument repair question MG 3
F Newbie Hardtop Question MG 7
norcalnewb Newbie Intro and Question MG 7
B Battery question from a newbie MG 5
jerrybny Fuel Question from newbie Triumph 58
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
steveg TR6 Newbie looking for hopup guidance Triumph 15
njunear Newbie - to this forum, that is........ Austin Healey 8
S TR2/3/3A Newbie Triumph 15
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
D aspiring AH newbie: some questions Austin Healey 16
steveg Newbie questions on pulling an engine Austin Healey 19
S MGB Newbie 1978 MGB questions MG 11
5 Newbie looking at a '67 Austin FX4 Taxi... Other British Cars 15
T Newbie Bugeye Sprite owner engine advise needed Spridgets 5
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
S MGB-GT Newbie researching MGB GTs MG 28
S General TR Newbie looking for 2+2 Triumphs and other makes Triumph 15
Steve P. Newbie with more questions Racing 8
